Bathroom Basement Rough-in - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2012, 12:05 PM   #1
Bathroom basement rough-in
The attached picture is what is roughed in for a bathroom in a basement.
Some obvious items are:
1 - toilet stack.
3 - Main stack (connected to two upstairs bathrooms.
Uncertain items
2 - Appears to be a vent. It travels across the wall horizontally (not shown) past number 3 to some plumbing for a washer and laundry tub.
4 - appears to be a clean-out.
Question:
If I wanted to put in a toilet and sink, where do I connect the sink drain? Can I connect to the vent for drainage? Or do I need to tie into the main stack (3)?
There also appears to be no rough in for a shower if 4 is a clean out? (Larger picture of 4 attached.)
rWeb is offline   Reply With Quote
Old 06-11-2012, 05:59 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 682
Some of your pipes confuse me--
#1 looks like a clean out plug. Haven't seen toilet stubs look like that
#2 may be a vent. Is it about 42" above the floor and connect to the washer vent? You can probably use it for the lav
#4 looks to me like a backwater valve. Unscrew the lid and see if there is a round flapper in there.
Old 06-13-2012, 06:46 AM   #3
#1 is a toilet stub. I guess they put that on to cap it.
#2 goes from the basement floor (under the concrete) up to the second and third floors. It is a vent for the laundry and appears to also vent the 2 washrooms on the second and third floors.
#4 is a backwater valve.
Question still remains where to tie a sink into? Maybe better off tying into the main stack (#3).
Old 06-13-2012, 08:30 AM   #4
Plumber
Rewards Points: 682
Tie into #2, not the stack. Its looks like the vent for the toilet. It's pretty standard to wet vent a lav there.
3 piece bathroom rough in newfieblue Plumbing 9 03-08-2012 04:35 AM
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 04:54 PM
Could use advice regarding plumbing for a basement bathroom raaczb Plumbing 3 01-22-2011 12:22 PM
Basement Bathroom Costs ktulu05 Remodeling 15 04-20-2009 01:24 PM
Basement Bathroom Rough In snowwhite49 Plumbing 2 05-26-2008 09:11 AM
