Bathroom - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-07-2011, 09:02 PM   #1
bathroom
my shower and sink dont get enough cold water the problem just started a couple of days ago
hazelaverelay is offline   Reply With Quote
Old 05-07-2011, 09:05 PM   #2
cold water problem
Do you know what kind of supply line pipes you have? If you have galvanized water lines, common in lots of older homes depending on your area, your pipes may have clogged from mineral build up inside. If not, you may have a leak somewhere, causing low pressure to a certain area.
jbarkley is offline   Reply With Quote
Old 05-09-2011, 10:07 AM   #3
Check your supply line.
genie01 is offline   Reply With Quote
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 10:00 AM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
gutting bathroom debiasio Remodeling 30 02-17-2011 03:32 PM
Bathroom fan replacement reveals...a mess merlanvp Electrical 0 07-25-2010 09:00 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
