Bathroom 1.5" Vent Tie Into 2" - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-23-2014, 04:45 PM   #1
Still Decompressing
Rewards Points: 255
Bathroom 1.5" vent tie into 2"
I am tying in the vents for my basement bathroom addition. I have the 1.5" vant from the sink/lav tying into the 2" vent from the shower drain.
Is it ok to use a san Tee on its side to join the 1.5inch into the 2 inch?
caveeagle is offline   Reply With Quote
Old 12-23-2014, 04:57 PM   #2
Be sure to tie in above flood level on main floor
gassyplumber is online now   Reply With Quote
The Following User Says Thank You to gassyplumber For This Useful Post:
ben's plumbing (12-23-2014)
Old 12-23-2014, 06:34 PM   #3
Rewards Points: 2,472
Yes as long as your are 6 inches above the highest fixture on that floor. Normally 42 inches is a good starting point.
Ghostmaker is online now   Reply With Quote
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
ben's plumbing (12-23-2014), caveeagle (12-23-2014)
Old 12-23-2014, 08:39 PM   #4
Still Decompressing
Rewards Points: 255
Yes, both the 2" and the 1.5" vent lines are running along the top wall frame of two perpendicular walls. So they will tie together at the corner before makeing the turn up to the main level floor joists.
I have a 2"x2"x1.5" wye, so I could use the why&a 45' to join the corner. (hope this makes sense)...
Using the 2"x2"x1.5" san-Tee just keeps the lines closer to the framing and will make for a cleaner install. So if thats ok... I will just run with that configuration.
dryer/bathroom vent terminations and window clearances itsnotrequired HVAC 14 04-29-2012 08:55 PM
Bathroom Rough-In- Mystery Vent flyboy Plumbing 10 04-10-2012 10:37 PM
Wrong roof vent for bathroom exhaust? vanishingson Roofing/Siding 18 04-04-2011 07:25 AM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 10:35 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
