Bath Vents - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2009, 03:28 PM   #1
Rewards Points: 37
bath vents
Hi,
My NuTone/Broan bath exhaust vents seem very drafty and let in quite a bit of cold air. The light cover feels cold and I can hear the flapper moving on high wind days.
What is the best way to seal the vents? I know that the units have a plastic flapper on them, but they don't seem to seal very well. I know that I need the vents but there has to be a better way to control drafts. My parents 50+year old home has vents, but they are not cold.
Thanks.
nbmech is offline   Reply With Quote
Old 01-09-2009, 03:35 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
What type of exhaust outlet does it have exiting the house, and is it mounted on a wall ?,roof ? or soffit. BOB
Old 01-10-2009, 06:55 AM   #3
NB,
My nutone fans have a black plastic collar with damper at the actual box in the bathroom. Tthis damper should function by blowing open, then dropping fully closed when ther is no pressue.
At the outside I have replaced my plastic vents for dryer and fans with a heavy gauge steel riveted vent hood. This device has a well built hinge and a washer with bolt for weight drilled through the door so it closes fully and QUIETLY and doesn't rattle in the wind. It cost abot $20 at HD and included about a 12" neck extension. I foam sealed it and my laundry room and kitchen are noticeably warmer now in the morning.
Nutone also makes a bulkier hood with a styrofoam ball that rolls up an incline to relieve exhaust and then rolls back down. It looks quite good, but bulky and when I held it up to daylight I could see a bit of light still around the ball and I want to aseal out the cold... Great concept but my bigger fear is that the styrofoam will eventually wear or chip.
Chemist1961 is offline   Reply With Quote
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Removing some vents rdmccaw HVAC 4 10-22-2008 01:00 PM
ridge/soffit vents not enough?? cbice74 Roofing/Siding 1 06-16-2008 05:02 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 09:47 AM
