Bath Tub Vent - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2012, 11:54 PM   #1
Bath tub vent
Can I run the drain after the P-trap, the length of the 5' tub, to the opposite wall before I Tee down and vent up?
KShirriff is offline   Reply With Quote
Old 11-02-2012, 11:57 PM   #2
In other words can I have my vent pipe for a 1-1/2" drain about 5 feet from the P-trap?
Old 11-03-2012, 06:53 AM   #3
DIY staff
Rewards Points: 7,174
Yes---Depending on your local code---5 to 6 feet is allowed and works just fine.
KShirriff (11-03-2012)
Old 11-03-2012, 07:58 AM   #4
Rewards Points: 2,512
see if this helps
hammerlane is offline   Reply With Quote
The Following 2 Users Say Thank You to hammerlane For This Useful Post:
KShirriff (11-03-2012), TheEplumber (11-03-2012)
Old 11-03-2012, 09:47 AM   #5
I'm in Alabama if that helps.I'm installing a bathtub on the second floor and thought of trying to put the vent up through the same 2 x 4 wall with the control valve and supply lines. It just seems a little tight.The other option would be to put the tee in the opposite wall and vent up.If I'm reading the chart correctly, for a residential home I can do that.
Correct?
Old 11-03-2012, 07:14 PM   #6
DIY staff
Yep----your plan will work---
Old 11-03-2012, 09:23 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 350
Correct?
Putting the vent at the head is done all the time to keep the trap arm short(UPC length is 3'6") Just put the vent to the stud bay left or right of the valve and use a 90 to hit the trap. Now all the plumbing is in one wall and not conflicting with the valve
Tags
bath and shower , bath tub venting , bath vent , venting
plastic pipe for bath vent tns1 Plumbing 1 09-22-2010 02:00 PM
help: distance from upstairs toilet vent stack to a new downstairs 1/2 bath Heikks2002 Plumbing 3 01-15-2010 11:21 AM
Bath vent problems arjan12 HVAC 5 01-09-2010 01:12 PM
Where to vent bath fan Ineedhelp2009 Electrical 8 03-17-2009 02:06 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
