Bath Tub Space Rough In - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2012, 10:29 PM   #1
Rewards Points: 660
I am finishing off my basement and am currently in the framing process. I am getting a 60" tub. Not exactly sure which kind yet, have it narrowed down.
My question is the dimension of the rough in space. I would like to wait on getting the tub as I don't need one more thing sitting in my way.
Should I make the opening exactly 60" or a half inch more?
Should I not fasten this "wall" to the ground so I can swing it shut once the tub is in?
If the tub is 30" wide, how far out should I build the wall? Is that just a matter of personal preference?
B
Beepster is offline   Reply With Quote
Old 02-13-2012, 10:42 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Frame at 60 1/8"
If all is square and plumb then fasten it down
It is personal preference. I typically frame at 34". This way you have a little drywall and a good corner for corner bead.
B[/QUOTE]
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-13-2012, 10:43 PM   #3
Rewards Points: 12,886
Anyway you can just have the back wall and one side wall in place and build the last wall once the tubs in place?
If not make it 60 1/8". A 1/2" would be to much.
I like to build my side walls out 6" past the tub. Makes it easyer to finish the drywall.
Old 02-14-2012, 09:32 AM   #4
Rewards Points: 660
Thanks guys. You guys rough in tubs a lot more than I do so I figured you would have the right answers.
B
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
Space needed for L-shaped staircase with 2 landings redpanda Building & Construction 1 07-28-2010 07:32 PM
bath remodeling alk01 Remodeling 1 07-10-2010 02:15 PM
new bath layout keoki Remodeling 2 06-30-2008 08:40 PM
