Bath Tub Leaks Only When Standing In The Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-07-2011, 11:26 AM   #1
Bath Tub leaks only when standing in the tub
Hi, My bath tub drain leaks only when standing and have shower in the tub. No problem when draining off bath tub water or when the shower is running with no one in the tub, what could be the problem and how do I fix it.......Bridget
mu992001 is offline   Reply With Quote
Old 07-07-2011, 11:43 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
It sounds to me like you might have a hard to see crack, possibly around the drain area where they seem to be most common.
Although it could be anywhere on the bottom of the tub. Close inspection is needed. It is also possible the drain is coming loose, I'd check that first.
DM
Old 07-07-2011, 11:55 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Plastic tub ???
XXX
Bath tub leaks Jimmy8056 Plumbing 3 06-04-2011 05:55 PM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 05:05 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
