Bath Tub Leaks - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2011, 02:32 PM   #1
Bath tub leaks
Bath tub leaks down below during shower only, opened the trim, no dripping noted from the pipes, have changed the Moen cartridge, now the leak has minimized but contine to drip during shower only.
Bath tub leak is on the second floor in a two storey house, and bath room leak water drains down on top of the kichen cabinets.
It is Moen's old shower assembly with push/pull shower lever.
There is a water stopper piston right next to the tub, but does not work.
Should I change the drain assembly? or
Remove the entire tub to see where the leak is occuring?
Any help is appreciated.
Jimmy8056 is offline   Reply With Quote
Old 06-03-2011, 03:35 PM   #2
Rewards Points: 1,578
Remove the damaged ceiling from below (has to be fixed anyhow) and see where the leak is coming from. May be from drain line etc...and nothing to do with Moen fixture.
bob22 is offline   Reply With Quote
Old 06-03-2011, 05:38 PM   #3
NACE Coating Inspector
mustangmike3789's Avatar
if it only leaks when the water is running, i would check the supply live going to the shower head or the tub spout. remove the plate at the valve and run the water to see if it is leaking there. that plate may have a bad seal too, so you may be able to eliminate 2 options at once. plug the tub drain and fill the tub a little. if your leak doesnt occure then it is probably the drain. if you cant eliminate the source at this point you may have to start doing some demo to get a better look.
mustangmike3789 is offline   Reply With Quote
Old 06-04-2011, 05:55 PM   #4
By looking from the opening down below (4x4 inches opening), the leakage/dripping occurs right below the tub drain stopper (drain stopper is a brass tube with pull up piston stopper since it is an old bath tub).
I truly appreciate your expertise.
Bath Fan Wiring into Existing Bath Light? DIY?... timstahl87 Electrical 3 04-13-2011 10:33 AM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 05:05 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
