Bath Tub Filling Up Very Slowly - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-29-2012, 08:29 PM   #1
Bath tub Filling Up Very Slowly
Our master bathroom tub fills up very slowly I have tried to figure out but can not. Our other bathroom in the house does fine. Any suggestions
Gardec is offline   Reply With Quote
Old 01-29-2012, 08:33 PM   #2
Rewards Points: 12,814
Any steel plumbing supply lines feeding that tub?
What size is the main lines supplying water to the tub?
Old 01-29-2012, 08:34 PM   #3
DIY staff
Rewards Points: 7,174
What kind of tub? If it is a tub with a deck mounted faucet---check the airiator screen on the tip of the faucet---
If it is a regular bath tub--what kind of valve? single handle of double? what kind of spout?
Old 01-31-2012, 09:48 AM   #4
Could this be a problem with your water pressure in your bathroom?
josh1998 is offline   Reply With Quote
Old 01-31-2012, 08:25 PM   #5
Rewards Points: 582
seeing is believing ..how about a picture of what you have?
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (01-31-2012)
Old 01-31-2012, 10:41 PM   #6
Old 02-01-2012, 12:48 PM   #7
Rewards Points: 256
In our last house I took apart the valve and every piece of assembly accessible; there was a fair amount of grit build up in there. Flushed it all out and no more problems. It did have galvanized pipes for 50 years so I'm sure that's where it came from.
moneymgmt is offline   Reply With Quote
Old 02-01-2012, 12:56 PM   #8
DIY staff
That's a Moen---pull the cartridge (after you shut off the water)
Clean the valve body with some fine sandpaper--replace the old cartridge with a new one and let us know how it works.
Use a Moen cartridge pulling tool---
ben's plumbing (02-01-2012)
Toilet filling slowly. Fast after twisting wall valve. 100n3y Plumbing 8 06-30-2011 11:16 AM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 10:31 AM
toilet filling up reservoir to slowly humberguy Plumbing 4 01-25-2010 04:38 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 07:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
