Bath Tub Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-06-2011, 06:16 PM   #1
Bath tub faucet
When i turn on hot water, it barely runs. The cold is fine and all other faucets work fine on hot and or cold. Whats the deal??
shanon6 is offline   Reply With Quote
Old 10-06-2011, 10:17 PM   #2
Could be that your cartridge needs to be changed or is fouled/blocked with something.
VIPlumber is offline   Reply With Quote
Old 10-07-2011, 12:50 PM   #3
Mark Potter's Avatar
Rewards Points: 150
Your shower body has cold and hot are separate or is it all one handle system?
HP Properties Capital Projects
Mark Potter is offline   Reply With Quote
Old 10-08-2011, 05:53 PM   #4
It is a seperate hot and cold
Old 10-08-2011, 05:55 PM   #5
Well what exactly is that, where is it? I try to get a plumber out here and NO ONE WANTS TO CALL ME BACK....so i guess i need to go to school
Old 10-08-2011, 05:59 PM   #6
Rewards Points: 150
There are stems inside your wall that comes out to your handle it could be stripped take a pic and send it if you can.
H|P Capital
Old 10-08-2011, 06:01 PM   #7
DIY staff
Rewards Points: 7,174
Pictures will help---If you can see a brand that will help also.
Old 10-08-2011, 06:16 PM   #8
Ok, i HAVE to watch this football game, lol. I will send a pic at half time. Im not sure i have the proper tools to remove the handles. So i will send a pic of the handles on and see if i can remove also. THANK YOU SO MUCH for the reply...
Old 10-08-2011, 06:18 PM   #9
Ok i will get some pics, umm the brand may be a different story. it has been here a while. thank you so much for the help
Old 10-08-2011, 06:25 PM   #10
DIY staff
Tools are usually--pocket knife to remove plastic cap- phillips screw driver--crescent wrench--pliers--
Old 10-08-2011, 06:26 PM   #11
Ok well i have that!! thanks
Old 10-08-2011, 06:39 PM   #12
Rewards Points: 150
Let us know if you got the handle and stem cover off be fore you go any farther.
H|P Capital
Old 10-08-2011, 06:41 PM   #13
Ok, will do
quote=Mark Potter;744664]Let us know if you got the handle and stem cover off be fore you go any farther.
H|P Capital[/quote]
Old 10-08-2011, 07:08 PM   #14
Ok i added a picture..i got the handle off!!! yaaaay!!
Old 10-08-2011, 07:10 PM   #15
Ok its off and added a picture
Originally Posted by shanon6 View Post
Ok, will do
H|P Capital
[/quote]
Right tool to remove cartridge of single handle bath sink faucet? darsunt Plumbing 2 05-20-2011 10:01 AM
Bath faucet pop-up drain rod won't fit sink hole location seavlad Plumbing 7 02-03-2011 06:23 PM
Good grief, 1956 American Standard bath faucet repair problem David911 Plumbing 4 02-27-2010 04:33 PM
Replacing bath tub faucet handles dave6k Plumbing 4 02-03-2010 07:55 PM
how to remove roman bath faucet? tarheelblue Plumbing 1 06-07-2008 06:38 PM
