Bath Tap Repair - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2011, 09:40 PM   #1
Bath Tap Repair
Hey,I am a trades person,not a plumber,and in the past I have always done my own repairs in my own home,to date I have replaced all the taps in my house except the lower bathroom,there is no shut off valves so I will be turning off the main water valve and drain both hot and cold water from the lines,something I have done in the past already,old house,recently a friend told me when you drain the lines in the entire house for a plumbing repair you should turn off the gas water heater ,is this correct I have never turned or shut down the water heater for a plumbing repair,the water will be off for probably 3 hours as I will be taking the old bath taps to the hardware store to match up ,any help on this would be appreciated,thank you,PS ,its the bath tub taps in basement.
mcex is offline   Reply With Quote
Old 01-20-2011, 06:25 AM   #2
As long as there is water in the tank, there is no problem. For gas, turn the temp down to low, for electric, switch it off, just to be safe.
The Following User Says Thank You to Just Bill For This Useful Post:
oh'mike (01-20-2011)
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 08:49 AM
Good grief, 1956 American Standard bath faucet repair problem David911 Plumbing 4 02-27-2010 04:33 PM
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 05:05 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
