Bath Sink Faucet Posts Are Too Short To Connect - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-10-2012, 10:43 AM   #1
bath sink faucet posts are too short to connect
I installed an new bath vanity top and when I went to install the new faucet, the posts are too short to connect to the water supply below. What do I do?
lenno is offline   Reply With Quote
Old 10-10-2012, 10:46 AM   #2
the Musigician
DangerMouse's Avatar
They make supply lines in many different lengths for just this reason. You just need to measure and find them at your local hardware/plumbing store.
DM
Old 10-10-2012, 10:47 AM   #3
Rewards Points: 13,300
Did you install the top then try and install the faucet?
I always install the faucets and supply lines, to the top then set the top in place. This way you can see what your doing and find any problums.
Without at least a picture it's hard to say why it's not working.
Most stems are made way to long to make up for differant thicknesses of the tops.
Old 04-04-2013, 03:34 PM   #4
Faucet installation is fairly easy and not too time consuming. You want to check this out -http://expressplumbingok.com/services/tips/item/74-researching-bathroom-sink-faucets.
It has has useful information about choosing the right bathroom sink faucet.
jsterna41 is offline   Reply With Quote
Old 04-04-2013, 03:54 PM   #5
Roofmaster
Rewards Points: 2,172
Joe is right on the money. I never do it any other way. They make supplies in any length you require. You always buy a little longer than you need, install to the fixture with vanity top clamped vertical. Always put plumbers putty under the fixture plate, Install tailpiece and pop up then drop the vanity top in place, the hook her up. Never over tighten supplies, and always use braided stainless or solid copper with brass ferrules.
Old 04-04-2013, 05:24 PM   #6
Sure sounds like it's not the supplys that are to short it's the two fitting coming out of the faucet that are to short to connect to.
Must be one thick top.
What's the top made of?
Old 04-04-2013, 06:01 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 452
I think you need to let this thread die of old age...
Old 04-04-2013, 07:29 PM   #8
Rewards Points: 582
agree with e...let it die because if its not fixed by now it won't get fixed
Old 04-04-2013, 07:33 PM   #9
bbo
you kidding me? i have projects started in 2006 I'm still mulling over ...
bbo is offline   Reply With Quote
Old 04-04-2013, 07:39 PM   #10
the cheap faucets used to be too short to connect on thicker countertops. what kind of faucet is it? i would guess a cheap one or you have really thick counters. can you bore a recess in the bottom of the countertop?
Old 04-04-2013, 07:42 PM   #11
Rewards Points: 582
hey danny good thougth...did you see the date of this one 10-2012 now you see why we said let it die
Old 04-04-2013, 10:28 PM   #12
Master Plumber
Javiles's Avatar
Rewards Points: 990
Too Many plumbers watching the walking dead.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Moen Sink Faucet A Smith Plumbing 1 06-02-2012 06:43 PM
vessel sink drain and faucet Katmac Plumbing 17 10-11-2010 09:12 PM
Caulking around kitchen sink deeaa Remodeling 8 07-13-2008 04:12 PM
Quick connect sink? rick32 Plumbing 2 12-13-2007 02:07 PM
Need Help with double bath sink trap after remodel cmontel Plumbing 13 12-03-2006 07:06 PM
