Bath Sink Change Out - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-04-2015, 06:33 PM   #1
Rewards Points: 1,192
Bath sink change out
I'm going to change our bath sink faucet . Not routine for an electrician, so I bought those s.s mesh hose hook up lines and a Moen unit. Do I use thread sealent and plumbers putty on this? The faucet has a vinlyn base it sits in.
bobelectric is offline   Reply With Quote
Old 01-04-2015, 06:48 PM   #2
DIY staff
Rewards Points: 7,174
Do not use anything on a flexable connection--those work by compression--the threads are only there to press the rubber connection together---
You might need plumbers putty under the faucet---most likely--no--as most use a foam gasket--read the instructions.
Old 01-04-2015, 06:58 PM   #3
Thanks, Oh'Mike. Guys in the field don't wanna give info up where they can make a buck.
Old 01-04-2015, 06:58 PM   #4
Rewards Points: 13,732
I'd pick up some plumbers putty for the drain where it meets the basin.
It's cheap.
Old 01-04-2015, 11:12 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 678
Might want a basin wrench too. Makes it easier to reach the faucet nuts
Old 01-05-2015, 01:32 AM   #6
Thanks, E. I did buy a basin wrench. Part of my collecting tools era.
The Following User Says Thank You to bobelectric For This Useful Post:
oh'mike (01-05-2015)
better bath sink drain? wkearney99 Plumbing 14 11-11-2014 09:53 AM
Hairline crack in porcelain bathroom sink stripedbass Plumbing 11 09-03-2014 06:38 AM
Advice on Replacing Rusted Bath Undermount Style Sink mdonovan Plumbing 12 11-09-2013 02:36 PM
Offset Bath Sink - Is this okay? chsitko Plumbing 8 04-23-2012 11:42 PM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 06:24 AM
