Old 01-03-2013, 01:33 AM   #1
Bath/shower control with hotter water bypass?
I'm looking for a faucet / bath / shower control that I thought I saw a long time ago that had a feature that allowed a user to run hotter water than was normally allowed.
So a parent could run a hotter bath for themselves, but a child would be unable to do so.
Now, when I search for the item, I can't find one. Can anyone point me to where this item might be found?
Thanks,
toddmanqa
toddmanqa is offline   Reply With Quote
Old 01-03-2013, 02:07 PM   #2
Grohe makes such a valve, but the high limit (on override) is supposed to be set at the max allowed by the state, so when the handle is turned up against the limit stop, the water will be somewhere around 100*F; press the button an turn it up to 115*F (+/-).
The limit stop on most valves can be overridden permanently, but of course you run the risk of scalding someone.
Ishmael is offline   Reply With Quote
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 05:10 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
