Bath Replumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2010, 01:37 AM   #1
Bath Replumbing
I have a question about my existing plumbing. I have a one story rambler with a crawl space. The plumbing enters at one end of the backside of the house, in the crawlspace, and continues to the other end (about 80 feet).
I am trying to replumb my main bath. My question is about the existing plumbing. Would there be any reason for a hot water line to extend from the hot water heater (located in the main bath), run down to the outside wall, over to the kitchen (to the sink / dishwasher), then back to the main bath (shower / sink). It seems like the water would be almost cool by the time it gets to the shower. The lines are copper - 1/2" from the fixtures and 3/4" along the crawlspace (I believe that right, but not completely sure).
I made a diagram of the plumbing to try to get an idea of the arrangement. The hot water lines are red and cold water lines are black. I am trying to move the sink to the other side of the room on the outside wall. The bath is approximately 11' long x 9' wide. The house is 50 years old.
I had to remove the floor as it had become unstable, so I thought it would be a good time to replace at least some of the existing lines, especially if it would make sense to reroute it differently. I am not sure why it was done the way it was, maybe due to acess.
lynda2006 is offline   Reply With Quote
Old 08-11-2010, 01:57 PM   #2
Just call me Andrew
Rewards Points: 1,020
Your word document is coming up blank...
Andrew
secutanudu is offline   Reply With Quote
The Following User Says Thank You to secutanudu For This Useful Post:
lynda2006 (08-11-2010)
Old 08-11-2010, 08:19 PM   #3
Rewards Points: 276
Based on what you are describing I would sat it is worth your while to put in a more direct supply from the hot water tank while you have your floors opened up. It is certainly easier than doing it later down in the crawlspace. Pipe insulation would help slow down the cooloing aw well.
Jim F is offline   Reply With Quote
The Following User Says Thank You to Jim F For This Useful Post:
Old 08-11-2010, 08:21 PM   #4
More files
Andrew,
Thank you for letting me know. I had so many views and no replies. I wondered why. I am attaching different file versions.
I belive the one I attached was MS Word 2007. Did you try right clicking on the file. The problem is I don't use MS Word and the software I use is not recognized on the site. I am still trying to figure it out.
Old 08-11-2010, 08:29 PM   #5
Another File
Another try at a file.
Old 08-11-2010, 09:06 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 556
I would put a tee near your WH to supply hot water to the bathroom. I see no reason to double pipe the hot line as it is now.
The Following User Says Thank You to TheEplumber For This Useful Post:
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 05:05 PM
Tie into existing bath GFI circuit for new basement bath GFI? 8roty Electrical 8 07-27-2009 11:38 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Bath Box drainage all gone bad. HELP shwingirl Plumbing 14 01-03-2008 04:25 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
