Bath Renovation - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-23-2013, 04:51 PM   #1
Bath Renovation
I have towel closet that I wish to turn into a walk-in shower, concrete foundation.. Closet is about 8" away from the tub drain. Any recommendations?
The shower will be on the same side as the sink. Can I tap into the drain for the sink?
RickyG is offline   Reply With Quote
Old 08-23-2013, 05:12 PM   #2
DIY staff
Rewards Points: 7,174
I moved this to plumbing for you.
You might get lucky---but maybe not---
Showers require a 2 inch drain under the slab---tubs only need 1 1/2" ----newer under slab plumbing is usually 2 inch---older houses---maybe not---in that case you will need to open the slab to the lateral drain for the toilet---
Get your jack hammer out and see what you have------Mike----
RickyG (08-24-2013)
Old 08-23-2013, 06:24 PM   #3
Mike is correct 2" for a shower drain and a vent you can probably tap into the tub vent if there is one if not youll have to run one. As far as the shower the tub drain is 1.5 so youll need to cut it back to the lateral to get it to 2".. Definitely have some jacking up to do..gl
Peppe1019 is offline   Reply With Quote
Old 08-23-2013, 07:23 PM   #4
MarginallyQualified
Rewards Points: 2,464
How big is this closet?
Old 08-24-2013, 07:52 AM   #5
Rewards Points: 3,130
I was wondering the same thing. I've never seen a towel closet large enough to turn into a shower.
Old 08-24-2013, 12:09 PM   #6
It 30" X 55" seating at the end of dual sink that stretch 8ft long. I was thinking of bring the sink closer together giving me more room to open up the closet. On the opposite end of the dual sink is the entrance from the bedroom to the bathroom. Just pass the entrance is the toilet.
Along the opposite wall is his closet, tub & shower combo, then her big closet.
The Following User Says Thank You to RickyG For This Useful Post:
oh'mike (08-25-2013)
Tags
bathroom remodel , plumbling , shower
Full bathroom renovation - bath to shower Dedalus9 Plumbing 6 09-21-2011 08:29 AM
Adding Master Bath - layout ideas bainer1290 Building & Construction 0 01-26-2011 09:31 AM
Insulating old house bath renovation Cossack Building & Construction 1 08-18-2010 07:56 AM
Basement Renovation Planning: Help! navi_jen Plumbing 0 06-16-2010 09:41 AM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
