Bath Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2007, 06:48 AM   #1
Guest
Guest
Posts: n/a
Question
bath floor
I am trying to add a second bath to my home. For the first time Im planning to carve up a section of the concrete block slab and dig down three feet to my sewer line made of pvc to tie into. I intend to use a skilsaw with a diamond tip blade and sledge hammer the concrete out after that to save from hiring it out. My questions would be: Can I tie into the existing sewer line with a 90 degree angle without back up troubles? When I cut the floor will I hit rebar and I assume its ok to cut through it? Is the concrete about 4 inches thick like I think it is? And is it ok to have such a steap slope from the new bath toilet flange down three feet over a six foot distance across the room. Can I tie in the toilet new sewer line and the new shower drain line both at that 90 degree curve down in the floor at the main sewer line three feet under ground Or should I Y them off farther above that point? Help!!
Old 02-20-2007, 06:20 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Use a wye combo.
Sure no problem, hit rebar cut it out of your way.
I'd maintain 1/4" per foot. So wjere ever seem good to you.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-20-2007, 07:03 PM   #3
Guest
Guest
Posts: n/a
Cool
1/4 inch per foot
to maintain a 1/4 inch per foot falloff i would have to dig up a section of the front yard and extend the lines out to keep a constant steady slope. is that correct or can i keep the line steap on the inside of the home slab and keep it simple at 6 inch fall of per foot to the main sewer line under the slab. the slab tapers at 1/4 inch per foot after the slab.
thanks for any input you can give.... i read everything even if i dont make any sense......
Old 02-20-2007, 07:07 PM   #4
Journeyman Plumber
Maintain 1/4" per foot till you get close to the connection, then make the drop.
Old 02-20-2007, 10:28 PM   #5
Guest
Guest
Posts: n/a
Talking
I bow
thank you for your assistance. I greatly appreciate it.
Old 02-20-2007, 10:35 PM   #6
Guest
Guest
Posts: n/a
You are wise
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
pipe size for tub, floor, and bath sink drains amakarevic Plumbing 2 07-25-2007 07:29 AM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 09:23 PM
Simple Bath Floor Questions Riddler Flooring 2 06-27-2006 10:41 AM
Help wih floor extremer1519 Flooring 1 12-27-2005 06:33 PM
