Bath Fixtures - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2010, 04:10 PM   #1
Bath Fixtures
I just installed my backer board for tiling and want to make sure the gap is filled properly here before tiling. Should I caulk ?
bwad is offline   Reply With Quote
Old 08-25-2010, 05:38 PM   #2
Rewards Points: 150
Looks like something is missing, is that the valve for a shower?, if it is you didn't leave the plaster guard on which determines the size of the hole, it also determines how far out of the wall the valve should be, you should check it before you continue.
You don't caulk around the valve.
braindead is offline   Reply With Quote
Old 08-25-2010, 07:23 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 904
I maybe wrong but shoudn't the notch on that collar be facing up? Doesn't it receive the cartridge keeper pin?
Your trim plate should have a sealant strip on the back side. It will press against the tile. I usually use clear caulk around the plate after insallation.
Old 08-25-2010, 08:11 PM   #4
Aren't you supposed to caulk around only the top half of the trim plate, leaving the bottom open so that if water does get in, it can get out again?
JackG is offline   Reply With Quote
Old 08-25-2010, 08:40 PM   #5
Actually the pic is sideways. I was thinking maybe I could fill in with thinset and fiber tape and just use redguard to waterproof. Would that work
Old 08-25-2010, 09:26 PM   #6
Plumber
Rewards Points: 904
As braindead said, the valve should have came with a "mud ring" installed on it. Its a temporary plastic ring about 3.5" diameter. Its used to gauge how close you cut the board and tile to the valve body. Some trim plates are beveled (concaved) and need that space for a proper fit to the tile. Your pics show the backer board too close. You can not service that valve cartridge. The trim plate offers enough waterproofing if installed correctly.
Old 08-25-2010, 11:05 PM   #7
Okay. So what you are saying is that the hole in the backer Board needs to be bigger because I also need the screw holes to attach the faceplate to ?
Old 08-25-2010, 11:12 PM   #8
Plumber
Rewards Points: 904
Old 08-26-2010, 12:05 AM   #9
Okay so her is the new cut. Is this good enough ?
Also, What about the little gap in the copper spout pipe on the bottom. Should this be caulked ?
Thanks for all your help.
Old 08-26-2010, 08:52 AM   #10
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It still looks too small by my eyeball, but its kinda hard to tell by that picture. Where is the mud ring?
Journeyman Plumber
Bath fans--how to send 2 to 1 exhaust outlet Bertha HVAC 5 02-22-2010 05:05 PM
Installing Light Fixtures in Bath mrsjande Electrical 8 09-03-2009 02:19 PM
Master Bathroom Fixtures mpt1123 Plumbing 1 03-01-2009 04:08 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 06:45 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
