Old 02-20-2013, 07:37 PM   #1
Trucon01's Avatar
Bath fixture removal
Hi All,
Not sure if anyone has seen these, but I need to know if there is a shutoff, besides the main. I'm trying to take down the tile tonight and need this off the wall.
Could the shut off be inside the wall?
Bath fixture removal-photo-1.jpg   Bath fixture removal-photo-2.jpg   Bath fixture removal-photo-4.jpg
Basement Demo started Jan 2012:
Bathroom demo started Feb 2013:
Trucon01 is offline   Reply With Quote
Old 02-20-2013, 07:40 PM   #2
MarginallyQualified
There *should* be.
What's on the other side of the faucet wall?
Old 02-20-2013, 07:47 PM   #3
Trucon01's Avatar
Just the wall to the bedroom No access panel. Looks like I'll have to break around it to find out.
If there is no shut off, I'll have to shut off the main. Once the main is off, How can I cap these pipes?
Old 02-20-2013, 07:57 PM   #4
call me E
TheEplumber's Avatar
Find your main shut off and then cap the what looks like 1/2" nipples at the 90's. If the pipes are CPVC- be careful that you don't tork and break them
The Following User Says Thank You to TheEplumber For This Useful Post:
Javiles (02-20-2013)
Old 02-20-2013, 08:14 PM   #5
Trucon01's Avatar
Any suggestions on what type of cap to use? Also, am I cutting off the 90s and capping the straight pipe, or the 90s themselves?
Could you also take a look at my other post in Plumbing? PVC flange to ABS pipe?
Old 02-25-2013, 05:11 PM   #6
Trucon01's Avatar
Hi All,
What type of CPVC cap can I put on these pipes after I remove the fixture? Can someone send me a link from HD, possibly?
Old 02-25-2013, 05:33 PM   #7
"You can do anything"-Mom
brockmiera's Avatar
http://www.homedepot.com/h_d1/N-5yc1...z114wr=1z114wr
brockmiera is offline   Reply With Quote
Old 02-25-2013, 05:34 PM   #8
Trucon01's Avatar
Thanks for the link. Use the same primer and cement that you use for regular PVC?
Old 02-25-2013, 05:38 PM   #9
brockmiera's Avatar
HD has some CPVC cement. You may be able to find a threaded cap that you can put right on the end of that 90*. I doubt you will end up keeping the pipes that are there now. What kind of mixing valve are you installing?
Old 02-25-2013, 05:42 PM   #10
MarginallyQualified
CPVC caps with CPVC cement.
Once the water is off at the main... and you've completed the demo install your line caps as far back and away from the work area as possible.
When you're ready to rebuild the wall and rough in...
add valves and a hatch nearby.
Old 02-25-2013, 05:56 PM   #11
If you just want a temporary cap w/o using cement, you could use a sharkbite. Easy on, easy off.
Being human is the result of heredity.
Being humane is a matter of choice.
retired guy 60 is offline   Reply With Quote
Old 02-25-2013, 06:56 PM   #12
Trucon01's Avatar
I found the 1/2 screw caps. Used some teflon tape, wrench tight, no leak.
Thanks again everyone!!
brockmiera-- Do you recommend a certain type of valve I should be using?
Electrical Short in New Light Fixture amateur1 Electrical 14 04-10-2012 08:45 PM
Hanging an overhead fixture jbcurrier Electrical 8 11-25-2010 12:19 PM
Frustrating bath spout removal problem martinvancouver Plumbing 6 07-09-2009 01:38 PM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 09:15 PM
Switching the Plugs in Bath Fan/Light MrBill_DIY Electrical 3 12-01-2008 07:45 PM
