-   -   Bath fixture removal (http://www.diychatroom.com/f7/bath-fixture-removal-172509/)
Trucon01 02-20-2013 06:37 PM
3 Attachment(s)
Hi All,
Not sure if anyone has seen these, but I need to know if there is a shutoff, besides the main. I'm trying to take down the tile tonight and need this off the wall.
Could the shut off be inside the wall?
TarheelTerp 02-20-2013 06:40 PM
There *should* be.
What's on the other side of the faucet wall?
Trucon01 02-20-2013 06:47 PM
Just the wall to the bedroom :( No access panel. Looks like I'll have to break around it to find out.
If there is no shut off, I'll have to shut off the main. Once the main is off, How can I cap these pipes?
TheEplumber 02-20-2013 06:57 PM
199 Attachment(s)
Find your main shut off and then cap the what looks like 1/2" nipples at the 90's. If the pipes are CPVC- be careful that you don't tork and break them
Trucon01 02-20-2013 07:14 PM
Any suggestions on what type of cap to use? Also, am I cutting off the 90s and capping the straight pipe, or the 90s themselves?
Could you also take a look at my other post in Plumbing? http://www.diychatroom.com/f7/pvc-fl...s-pipe-172478/
Trucon01 02-25-2013 04:11 PM
Hi All,
What type of CPVC cap can I put on these pipes after I remove the fixture? Can someone send me a link from HD, possibly?
brockmiera 02-25-2013 04:33 PM
http://www.homedepot.com/h_d1/N-5yc1...z114wr=1z114wr
Trucon01 02-25-2013 04:34 PM
Thanks for the link. Use the same primer and cement that you use for regular PVC?
brockmiera 02-25-2013 04:38 PM
HD has some CPVC cement. You may be able to find a threaded cap that you can put right on the end of that 90*. I doubt you will end up keeping the pipes that are there now. What kind of mixing valve are you installing?
TarheelTerp 02-25-2013 04:42 PM
CPVC caps with CPVC cement.
Once the water is off at the main... and you've completed the demo install your line caps as far back and away from the work area as possible.
When you're ready to rebuild the wall and rough in...
add valves and a hatch nearby.
retired guy 60 02-25-2013 04:56 PM
If you just want a temporary cap w/o using cement, you could use a sharkbite. Easy on, easy off.
Trucon01 02-25-2013 05:56 PM
1 Attachment(s)
I found the 1/2 screw caps. Used some teflon tape, wrench tight, no leak.
Thanks again everyone!!
brockmiera-- Do you recommend a certain type of valve I should be using?
