Old 11-15-2011, 01:27 AM   #1
P Marage's Avatar
Bath faucet replacement trouble
I need to replace my faucet for my tub but there's a stud in the way (pic1)
I dont want to remove the tile in the surround I cant afford to re-tile it right now but the faucet is leaking so it must be fixed, I do however have access to the plumbing from an access hatch behind the tub in my closet but like I mentioned theres a stud in the way.
The stud is notched so the pipe can cross past the stud.(pic1)
Can I cut that notch completely through the stud(pic 2cut), refill the gap with a block/shim and sandwich the shim & stud between 2x4's on either sides screwed with a little pl 400 for xtra strength (pic 3rebuild,) yellow=imagined repair :P.
Thoughts???
Thanx in advance for any help or other Ideas
Bath faucet replacement trouble-pic-1.jpg   Bath faucet replacement trouble-pic-2-notch-.jpg   Bath faucet replacement trouble-pic-3-rebuild-.jpg
P Marage is offline   Reply With Quote
Old 11-15-2011, 05:54 AM   #2
Super Moderator
That is not ideal as it weakens the wall holding the tile---If you must do that be very careful not to shake the wall and knock the backer board off---
Stiffen up the cut when you are done----
A multi-tool will make that cut without causing unnecessary damage.
oh'mike is online now   Reply With Quote
P Marage (11-15-2011)
Old 11-15-2011, 12:28 PM   #3
+1, just cut a chunk out of the stud, then when you are done, put the chunk back and reinforce it on the side with a longer piece of 2 x 4 that extends past the repaired area, screwing it above, below and into the cut out.
NitroNate is offline   Reply With Quote
The Following User Says Thank You to NitroNate For This Useful Post:
Old 11-15-2011, 12:52 PM   #4
P Marage's Avatar
Thumbs down
Thanx guys, @nitronate that's exactly what I had in mind. My incredible graphics in my 3rd pic was trying to show that
I figure worse case I bite the bullit and replace the tile. I have some left over from the original install if I have to replace any.
Old 11-15-2011, 04:00 PM   #5
You are going at it the right way just be sure and use sheetrock screws that are long enough to go through both pieces of lumber, no hammering with nails. I would suggest a good glue that is water resistant on both pieces of the wood before you screw it. That will give you a lot more strength.
You should be fine.
Tom
TGMcCallie is offline   Reply With Quote
bath panel replacement humpty Carpentry 1 09-15-2011 08:03 AM
Replacing Price Pfister cartridge bath faucet robwallis Plumbing 2 03-12-2009 11:29 AM
Shower faucet replacement - PVC replacing steel? jdm1 Plumbing 2 11-29-2008 12:38 PM
Replacement shower faucet? jlajla24 Plumbing 4 11-24-2008 06:17 PM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 03:02 PM
