Bath Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-25-2012, 03:25 PM   #1
Bath Faucet
I have a single pull/push bath handle, I need to replace the cartridge inside, problem is I cannot figure out how the handle is attached to the fixture. It appears the handle is one solid piece of metal. I can not find any set screws holding on the handle. The handle is simply a round piece of metal with grooves on it. I think it's a Moen faucet.
Frank
Frank Pipolo is offline   Reply With Quote
Old 06-26-2012, 12:30 AM   #2
Do you have a pic that you could upload? How to attach a photo to a post
VIPlumber is offline   Reply With Quote
Old 06-26-2012, 07:30 PM   #3
Pictures
Attached are a couple of pictures. The spot on the front is where I started to drill through cap, not plastic, solid metal. The white plastic piece in the back seems to be attached to handle. All around the handle is the same no set screws are visible.
Old 06-26-2012, 07:35 PM   #4
Rewards Points: 582
your right its a moen faucet....little cap should screw off or pop off...i think....you may go to www.moen.con look for your stlye....
The Following User Says Thank You to ben's plumbing For This Useful Post:
Frank Pipolo (06-26-2012)
Right tool to remove cartridge of single handle bath sink faucet? darsunt Plumbing 2 05-20-2011 11:01 AM
Bath faucet pop-up drain rod won't fit sink hole location seavlad Plumbing 7 02-03-2011 07:23 PM
Good grief, 1956 American Standard bath faucet repair problem David911 Plumbing 4 02-27-2010 05:33 PM
Replacing bath tub faucet handles dave6k Plumbing 4 02-03-2010 08:55 PM
how to remove roman bath faucet? tarheelblue Plumbing 1 06-07-2008 07:38 PM
