Bath Drain Won't Screw In All The Way - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2010, 06:56 PM   #1
Bath Drain won't screw in all the way
I'm trying to replace the drain in my bathtub. I have bought 3 different drains and none will screw in all the way. One hardward store employee said that some manufacturers may have different threads on their drains and that is why the drains I have purchased won't fit properly.
I can take the existing drain out no problem, and install it again with no problems. But any new drain doesn't seem to fit. Any recommendations on how to replace this drain?
tannerwi is offline   Reply With Quote
Old 05-12-2010, 10:16 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You probably need to buy a whole new waste and overflow kit if you're having that much trouble with it.
Journeyman Plumber
Old 05-13-2010, 03:42 AM   #3
Man of many hats
wrangler's Avatar
Rewards Points: 354
Take the original drain to a plumbing supply store, not a box store and they should be able to match it up. There are many different size/thread combos, You are probably trying to fit a 'B' dreain into a 'B-2' tub shoe, or vice versa. I've run into situations where the tub shoe were unusually shallow as well and ended up having to do as the previous post suggested and replacing the overflow and shoe assembly.
Man of many hats
wrangler is offline   Reply With Quote
Old 06-14-2010, 09:22 PM   #4
tub thread
I have the same exact issue, new tub drains from the big box hardware stores tend to have too much thread and bottom out in my drain before they tighten up and seal. I will try the plumbing supply suggestion and let you know what I find.
crlanglois is offline   Reply With Quote
Tags
tub drain
Very slow drain no drain blues Plumbing 16 04-03-2012 06:39 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
Can't get set screw in TP holder loose janralix Plumbing 4 08-12-2009 11:47 PM
Drop in bath tub center drain to lft drain mikerich28@hotmail.com Remodeling 1 04-16-2008 09:48 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 01:09 AM
