Basic Vent Piping - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2010, 08:53 AM   #1
the Musigician
DangerMouse's Avatar
Basic vent piping
I'll be redoing all the plumbing again now that The new rooms are going in.
Looking for a basic stinkpipe diagram to show me the do(s) and do not(s) of running the kitchen sink, bathroom sink(s) shower(s) and toilet(s). I'm thinking of adding a half bath. All fixtures are on the same level over a crawl space.
The new plumbing will be run through the walls inside the home as much as possible to avoid freezing temps down below. I'm trying to think through the vent pipes for all the fixtures. Any advise is greatly appreciated. I figure the more I know before I start, the faster I'll finish, doing it right to pass my inspection.
Thanks guys!
DM
Old 06-16-2010, 09:08 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Are you talking about like an ISO? Or are you looking for some other type of diagram?
The only thing an ISO really shows you is sizing, it doesn't really show fittings very well and length of piping. . .
Journeyman Plumber
Old 06-16-2010, 09:28 AM   #3
the Musigician
If I knew what an ISO was, (besides a cd image file) that might help with my answer. LOL
DM
Old 06-16-2010, 11:47 AM   #4
If you can diagram where you plan on putting the sink, toilet and tub with an outline of walls in your space, and which direction you need to go with the waste line, I can help with designing your system. There are just to many variables as it comes to waste and vent piping, distances, wet vents, etc... to give you any good advice.
The Engineer is offline   Reply With Quote
Old 06-16-2010, 11:58 AM   #5
the Musigician
Thanks. This graphic is sort of what I'm needing, just the basic setup. I'll have the kitchen sink, next room is the bathroom, so all vents will be close. I only want to make ONE hole in the roof to vent everything. The existing drains will just be extended 3' or so and also the main plumbing lines I already did a few years back. She wants me to add in a half-bath though, so I'm looking to 'back-to-back' the two toilets, one on each side of the wall, same with the two vanity sinks. But I imagine I'll be needing a new drainpipe for going under two toilets like that?
Also, in this graphic, there seems to be no vent for the tub/shower, is that right?
DM
Old 06-16-2010, 12:35 PM   #6
You can take the 2nd toilet into the same stack, no problem. You have to com off the bottom of the toilet and pipe to the 4" line the same way it pictured, only mirrored. Also, in the picture, the vent for the toilet is actually wet vented through the sink drain. A wet vent serves two purposes, it drains the water from the sink and acts as a vent for the bathtub. Perfectly legal in the configuration shown in the picture.
Old 06-16-2010, 09:02 PM   #7
Doing it myself
Alan's Avatar
Not in Oregon.
Journeyman Plumber
Old 06-16-2010, 09:07 PM   #8
the Musigician
Explain?
DM
Old 06-16-2010, 09:26 PM   #9
Doing it myself
Alan's Avatar
Each fixture requires its own vent EXCEPT when wet venting, in which case wet vents are required to be vertical drainage only.
Drain may not intersect another trap arm (between fixture outlet and vent opening) must intersect a drain only.
but that's just oregon. I know everyone has their variation.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
plummen (06-17-2010)
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
vent piping in attic demano Plumbing 4 05-24-2009 09:49 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
