Basic Plumbing Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-03-2012, 08:32 AM   #1
Basic plumbing question
I have two bathrooms on the second floor of my house. The drain is clogged so neither will flush. But (and here is my real question) the tub is also draining slow. Does plumbing code allow tubs and sinks to use the same drain as the toilets?
dedwards14 is offline   Reply With Quote
Old 09-03-2012, 08:38 AM   #2
Rewards Points: 212
Yes, Please see the attached
orange is offline   Reply With Quote
Old 09-03-2012, 11:05 AM   #3
In a little over my head
Rewards Points: 706
That should give you a hint where the clog is. Downstream of the Y, between the 1st and 2nd floor. Maybe you can run your snake down the vent from the roof?
ratherbefishing is offline   Reply With Quote
Old 09-03-2012, 08:20 PM   #4
Bombastic Idiot
notmrjohn's Avatar
"tubs and sinks to use the same drain as the toilets?" they all gotta come together somewhere.
And the pipe that delivers water to the kitchen sink is connected to the pipe that delivers water to the toilets. Or at least that's what my dad used to say when we'd call out after we weren't s'posed to get out of bed, "Dadeeee, I'm thirsteee." He'd bring in a glass of water from nearest source. "Ewwwww, not bathroom water!" Then we got the plumbing lesson. followed by the blessing. "Now drink the water, shut up, AND GO TO SLEEP!" mutter mutter stuff the litle mutter mutter down the mutter toilet mutter mutter
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-04-2012, 11:30 AM   #5
Thanks for your answers. The diagram is great. We're going to try rodding down the vent pipe from the roof.
outside corner basic question amakarevic Drywall & Plaster 8 05-11-2012 11:19 PM
plumbing question Clarissa Plumbing 2 05-09-2012 12:50 PM
Bathroom plumbing question muehleisem Plumbing 6 03-30-2012 06:36 PM
basic question - single pole switch in a 3-way setup dbpass Electrical 10 09-07-2010 05:29 PM
Utility Sink Plumbing Question justinL Plumbing 2 08-16-2010 08:10 PM
