Old 06-14-2012, 02:56 PM   #1
Basic Plumbing Question
So I have a 3/4" line coming in from the street, 1/2 tees off to the water heater and the 3/4" cold continues for about 20' teeing of 1/2" to fixtures, the hot is 1/2" for the 20' and also tees off to each fixture.
I am redoing a shower that is at the end of the 20' line. The valve I bought allows 3/4" lines. My question is, can I run the 3/4" cold to it and 1/2" hot to the same valve with an adapter? Will the different sizes do anything? Is it good bad or indifferent to do so? Any suggestions are welcome.
penlies is offline   Reply With Quote
Old 06-14-2012, 05:59 PM   #2
MarginallyQualified
Originally Posted by penlies View Post
So I have a 3/4" line coming in from the street, 1/2 tees off to the water heater and the 3/4" cold continues...
I am redoing a shower ... The valve I bought allows 3/4" lines.
Not much point to using any different size pipe than what you have there now.
Old 06-15-2012, 08:01 AM   #3
To keep pressure and flow rates up, all lines inside the house should remain 3/4 as close as possible to the fixture, before going down to 1/2. That includes the hot side.
The feed to the heater should have been 3/4, in and out of the heater. Poor house design, or execution.
Old 06-15-2012, 10:04 AM   #4
Doing it myself
Alan's Avatar
Uh.... is there some reason you bought a shower valve with 3/4" inlets?
(multiple function maybe?)
So here are your options.
If you didn't buy the valve for that purpose, maybe trade it for a valve with 1/2" inlets.
If you did buy the valve for that purpose, then you DO need a 3/4" line to keep up with volume when you're using multiple functions.
Journeyman Plumber
Old 06-15-2012, 07:05 PM   #5
3/4 inlets are sized for a reason...volume....feed it with 3/4 or return it for 1/2" supply.....ben..
The Following User Says Thank You to ben's plumbing For This Useful Post:
VIPlumber (06-15-2012)
Old 06-15-2012, 08:41 PM   #6
JetSwet's Avatar
All your fixture feeds should be 1/2". 3/4" for main lines.
JetSwet is offline   Reply With Quote
Tags
water line, water line size
outside corner basic question amakarevic Drywall & Plaster 8 05-12-2012 12:19 AM
plumbing question Clarissa Plumbing 2 05-09-2012 01:50 PM
Bathroom plumbing question muehleisem Plumbing 6 03-30-2012 07:36 PM
basic question - single pole switch in a 3-way setup dbpass Electrical 10 09-07-2010 06:29 PM
Utility Sink Plumbing Question justinL Plumbing 2 08-16-2010 09:10 PM
