-   -   Basic Plumbing Question (http://www.diychatroom.com/f7/basic-plumbing-question-147046/)
penlies 06-14-2012 01:56 PM
So I have a 3/4" line coming in from the street, 1/2 tees off to the water heater and the 3/4" cold continues for about 20' teeing of 1/2" to fixtures, the hot is 1/2" for the 20' and also tees off to each fixture.
I am redoing a shower that is at the end of the 20' line. The valve I bought allows 3/4" lines. My question is, can I run the 3/4" cold to it and 1/2" hot to the same valve with an adapter? Will the different sizes do anything? Is it good bad or indifferent to do so? Any suggestions are welcome.
TarheelTerp 06-14-2012 04:59 PM
Originally Posted by penlies (Post 943422)
So I have a 3/4" line coming in from the street, 1/2 tees off to the water heater and the 3/4" cold continues...
I am redoing a shower ... The valve I bought allows 3/4" lines.
Not much point to using any different size pipe than what you have there now.
Just Bill 06-15-2012 07:01 AM
To keep pressure and flow rates up, all lines inside the house should remain 3/4 as close as possible to the fixture, before going down to 1/2. That includes the hot side.
The feed to the heater should have been 3/4, in and out of the heater. Poor house design, or execution.
Alan 06-15-2012 09:04 AM
Uh.... is there some reason you bought a shower valve with 3/4" inlets?
(multiple function maybe?)
So here are your options.
If you didn't buy the valve for that purpose, maybe trade it for a valve with 1/2" inlets.
If you did buy the valve for that purpose, then you DO need a 3/4" line to keep up with volume when you're using multiple functions.
ben's plumbing 06-15-2012 06:05 PM
3/4 inlets are sized for a reason...volume....feed it with 3/4 or return it for 1/2" supply.....ben..:yes:
JetSwet 06-15-2012 07:41 PM
All your fixture feeds should be 1/2". 3/4" for main lines.
