Old 06-16-2006, 08:57 PM   #1
Finance Guy
Basement wetbar
Hey folks,
Another beginner question, I am sure, so I apologize to the many experts in the forum. As I design a re-finish plan for my basement, I am being strongly urged by my wife to add in a sink / wetbar area. I am very poor at plumbing, so appreciate any thoughts:
The main sewer line flows out through the opposite wall at approximately 46 inches above floor level. I can pretty easily tap into hot and cold water lines for the sink (they are even PEX to make it very easy), but the drain pipe is scaring me. Also, the vent line is about 10 feet away (horizontally).
My question is whether this is a workable situation, or whether this requires a pump to execute the drain connection. As usual, many thanks ahead of time for your assistance.
Best regards,
Swimm
Swimmfst is offline   Reply With Quote
Old 06-19-2006, 09:18 AM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Basement wetbar
It will require you to pump the sink waste up and out to the main. Vent should be simple if you have good access to the pipe.
Ron The Plumber is offline   Reply With Quote
Old 06-19-2006, 09:57 AM   #3
Finance Guy
Basement wetbar
roughly, how much cost in pumping the water up for a sink?
Old 06-19-2006, 06:54 PM   #4
Journeyman Plumber
Basement wetbar
Don't know, call and get estimates.
Old 07-08-2010, 07:46 AM   #5
Basement wetbar
I am doing the same thing and I plan on using a ventless wet bar pump called Hartell LTA-1. Excellent reviews and you simply just tap into the existing drain no need to worry about the vent. They run about 250.00 and they are easy to install.
http://www.hartell.com/Files/Hartell...structions.pdf
ryan5068 is offline   Reply With Quote
Old 07-08-2010, 09:22 AM   #6
Owner
LateralConcepts's Avatar
Basement wetbar
http://www.libertypumps.com/Products...?p=19&s=8&c=15
These are nice systems. Comes with everything you'll need except pipe and fittings, and will easily fit under the bar. Check with a local plumbing wholesale for pricing
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS,LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
LateralConcepts is offline   Reply With Quote
Do I need a HVAC return vent in basement? westing HVAC 12 01-28-2009 01:09 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 08:08 AM
Wet Basement being fixed (pics) harleysilo Remodeling 2 01-23-2007 09:09 AM
