Old 06-23-2009, 09:10 PM   #1
Cool Basement water heater "discharge line" proper draining ideas/options?
Dear all, first please take a look at this photo:
http://yfrog.com/0vwaterheaterlargej
We have a water heater in the basement that current there is no way for the discharge line to drain the water properly. The basement (and the whole house) is built with concrete so it's kind of difficult to dig a hole on the wall to allow water from the discharge line to drain properly. As a result, as you could see in the photo, is a damp basement and the floor is full of water stain/grease. Any idea how we could solve this problem? Thanks!
ohman is offline   Reply With Quote
Old 06-23-2009, 09:37 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
That vertical "discharge" line is from the T&P valve that only opens to prevent steam explosion of a malfunctioning water heater. A water hose can be attached to the drain at the bottom of a water heater to flush it periodically.
Doesn't your basement have a floor drain?
Mike
Mike Swearingen is offline   Reply With Quote
Old 06-23-2009, 09:37 PM   #3
Master Plumber/Mechanical
You can place the WH in a drain pan made for WH and seal the drain hole in the pan. Then install a water sensor device with and alarm. So that if the WH starts to leak or the TPV starts to leak the sensor will make the alarm go of to alert you of a problem.
Hopefully the pan will hold the water to prevent damage.
Google water sensor alarm there are alot to chose from. There are ones that you install to the water entrance to shut off water to the house in case you are away from home.
Old 06-23-2009, 11:17 PM   #4
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation Water heater discharge line
OR BEST OF ALL YOU CAN DO IT THE CORRECT WAY PER PLBG. CODE AND
INSTALL A THERMAL EXPANSION TANK ON THE COLD WATER PIPE BETWEEN
YOUR SHUT OFF VALVE AND THE TANK INLET TO ALLOW THE HOT WATER
TO EXPAND INTO TANK AND IT WILL NOT LEAK OUT OF THE DRAIN PIPE
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Old 06-24-2009, 03:20 AM   #5
Mike
Hi Mike thanks so much for your reply, really appreciate that!
Nope the basement does NOT have a floor drain. It is really weird, but I double checked it and really can't find one. The house was build in 193x (an art deco house in San Francisco), so...
Old 06-24-2009, 03:22 AM   #6
Plumber101, that is a very good idea! Thanks again!
More On This Topic
A boat leak can cause expensive damage to your boat and all of the items that you keep in it. It's important to quickly plug your boat leak to avoid further damage to your boat and to keep water out. Follow these instructions to help you identify the... Read More »
Hi, I'm Mark Sullivan for Expert Village and today we're going to teach you how to change the oil in a standard internal combustion automobile engine. So the next thing we're going to do is go under the vehicle and open the oil drain plug and we will let... Read More »
How to Replace Car Oil Plug
How to Replace Car Oil Plug by Expert Village
Now we are going to take our drain plug and going to put that back in the oil pan. Same thing here, we want to make sure that this plug is tight, so it is not going to leak and is not going to back itself out from the vibration of the car. You don't want... Read More »
How to Install a Drain Plug
How to Install a Drain Plug by Expert Village
Hi, I’m Dean Donnel for expertvillage.com. Now we’re going to install the drain plug. There’s a few things you need to know before you install your drain plug. You can get into trouble if you tighten it and don’t get your threads... Read More »
Okay so I cut all my potatoes, they are still sitting in the water so our next step is head over to the sink. We are going to go ahead and drain them into a colander. So I am going to pour into the colander and you want to make sure that you shake off... Read More »
Stumped. Water heater woes. bigcaddy Plumbing 35 06-14-2009 07:12 PM
water pooling ontop of water heater nannerkrns Plumbing 2 09-24-2008 12:04 AM
Tankless water heater vs. electrical water heater? imola ghost Electrical 19 09-08-2008 04:59 PM
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 11:37 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 08:01 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
