Basement Utility Sink Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2008, 08:10 AM   #1
basement utility sink install
Hello, I want to install a utility sink in my basement next to an existing pvc drain stack. There is a cleanout about a foot above the basement floor. I was wondering if I could remove the cleanout and install a tee (sanitary tee?) and put the cleanout back in above the tee. From the tee I was thinking about putting in a AAV between the sink and the tee. Also I was wondering how I reconnect the drain pipe after cutting it since both ends of the pipe are fixed (not moveable). Thanks...
bjkPoker is offline   Reply With Quote
Old 03-17-2008, 04:56 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
If AAV are allowed there, then I don't see why not.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 03-18-2008, 07:12 AM   #3
Thanks. What about connecting the pipe back together at the top? I'm assuming you can't use a regular coupler since the pipe pieces won't move.
Want to install larger window in basement wall andrewcocke Remodeling 8 02-24-2008 10:51 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
How Do I Install New Duct Lines For My Finished Basement? luweee HVAC 17 01-12-2008 03:01 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 07:30 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
