-   -   basement utility sink install (http://www.diychatroom.com/f7/basement-utility-sink-install-18613/)
bjkPoker 03-17-2008 09:10 AM
Hello, I want to install a utility sink in my basement next to an existing pvc drain stack. There is a cleanout about a foot above the basement floor. I was wondering if I could remove the cleanout and install a tee (sanitary tee?) and put the cleanout back in above the tee. From the tee I was thinking about putting in a AAV between the sink and the tee. Also I was wondering how I reconnect the drain pipe after cutting it since both ends of the pipe are fixed (not moveable). Thanks...
Ron The Plumber 03-17-2008 05:56 PM
If AAV are allowed there, then I don't see why not.
bjkPoker 03-18-2008 08:12 AM
Thanks. What about connecting the pipe back together at the top? I'm assuming you can't use a regular coupler since the pipe pieces won't move.
