Basement Utility Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-25-2007, 04:00 PM   #1
Basement Utility sink
I want to install one but the pipe leaving my house to the septic system is 3.5' above the basement floor (too high to drain the sink into by gravity). I've been told someone makes a combo plastic utility sink on legs with a sump/pump below - any advice on where to get these or if they are a good choice? Hot & cold water taps and the s-trap from the previous basement laundry are available for use (laundry was moved upstairs). The S-trap is 5' above the basement floor and drains into the main pipe to the septic system. Can the sink pump discharge into this?
JohnnyP is offline   Reply With Quote
Old 09-26-2007, 05:04 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
www.saniflo.com . Try this for a Sanipump.
And yes, you should be able to use the old washer drain and supply lines for a utility sink. You don't need an S trap. Use a P trap.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 09-26-2007, 07:03 AM   #3
You could also put a sink on a platform, with a P-trap. If the drain is 3.5' up, the sink would need to be about 4' up. Might be a little weird, but it could work if you have good headroom in the basement. Just make a step up to the sink.
Otherwise you'll need to use a pump-up system, to move the wastewater up into the waste line.
NateHanson is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
utility sink pump furiousstyles Plumbing 4 11-06-2009 03:52 PM
Cement Utility Sink - Cracks and Leaks amazinlittledevil Plumbing 3 01-25-2007 02:59 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
