Basement Tub/shower Drain With Radiant Heat - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-05-2012, 04:04 PM   #1
basement tub/shower drain with radiant heat
The plumbers roughed in about a 10 x 10 inch box out of the concrete with a stub drain pipe in the bottom. The problem is the wall (which the tub with sit against) had to be built right next to the edge of the hole. With the centerline of tubs usually around 15 inches, the drain isn't over the hole. Breakin out 5 more inches of concrete would be the simple solution if we didn't have radiant heat in the slab. Any ideas.
jamesdinger is offline   Reply With Quote
Old 03-05-2012, 04:11 PM   #2
Have any construction pictures of the floor before it was poured?
Maybe the PEX isn't that close. You could take small chunks at a time with hand tools.
Get an thermal image of the floor to pinpoint the locations of the pipes. Buy an inexpensive thermal gun and proceed carefully with those hand tools.
yogi_bear_79 is offline   Reply With Quote
The Following User Says Thank You to yogi_bear_79 For This Useful Post:
ben's plumbing (03-05-2012)
Old 03-05-2012, 06:37 PM   #3
Rewards Points: 616
if you do not have tub yet you could buy one that drain shoe fits between floor and tub the better fiberglass tubs that have 3/4 osb fiber glassed to bottom of tub then have four support feet or what is called above floor rough in tub i know american standard offers them in several of there tubs
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 03-05-2012, 06:46 PM   #4
Rewards Points: 582
when we install radiant heat in floors we stay at least 1foot away from pipes..I think some manuals suggest this...
Old 03-05-2012, 08:43 PM   #5
Thanks for the replies. It took about three hours but I have managed to break out an extra five inches. I did finally find the pex but managed to not damage it. I wish I had known about that above floor rough in tub before I started.
Old 03-05-2012, 08:49 PM   #6
Rewards Points: 616
and now you know the rest of the story
Need Help with Radiant + AHU Heat Coil Control Wiring Tommathome HVAC 0 04-03-2011 03:30 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Basement tub/shower below drain? WillProsper Plumbing 1 09-02-2010 07:41 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
