Basement Tub/shower Below Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2010, 03:00 AM   #1
Question
Basement tub/shower below drain?
We want to put a shower, or even just a tub, in the basement with a guestroom. Unfortunately, the sewer drain exits a full 2 feet above the floor. To make matters worse, the ceiling is less than 7 feet high, so there's no room to raise the unit above the drain.
Are there such things as pumps for showers/tubs? Like in a washing machine or dishwasher?
Last edited by WillProsper; 09-02-2010 at 03:04 AM. Reason: better explanation, and grammar.
WillProsper is offline   Reply With Quote
Old 09-02-2010, 07:41 AM   #2
DIY staff
Rewards Points: 7,174
You will need to dig a hole and install a sewage pit(like a sump pit)
A sewage pit will need a 2" vent and an effluent pump--Like a sump pump but able to handle solids
The effluent is then pumped into the main sewage drain.--Mike---
WillProsper (09-03-2010)
Tags
basement , pump , sewer , tub drain help
Laminate on basement floor, but there is a drain there nag Flooring 6 06-10-2010 09:59 PM
basement still leaking AFTER doing tile/gravel drain annie68164 Building & Construction 2 03-12-2010 08:22 AM
toilet drain is too close to the wall in the basement Kirock17 Plumbing 15 02-24-2010 08:07 AM
Basement Floor Drain & Sewer Gas 1914 Home Plumbing 4 09-26-2009 04:46 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
