Basement Toilet And Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2013, 10:58 AM   #1
Rewards Points: 214
Basement Toilet and Shower
Basement toilet and shower rough in in the planning. Is there a chance that the horizontal section of the vent could clog in this arrangement. Nothing is finalized yet.
rosem637 is offline   Reply With Quote
Old 01-01-2013, 08:47 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 672
Yes, Vents cannot join as you show. Must be 6" above the flood rim of the fixtures served before joining them
Old 01-01-2013, 08:58 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Holy @^#%^$% batman.
To add to the code reference above : Unless precluded by structural conditions (I don't see any), then the vent must be run as high as possible, before offsetting horizontally, and must be run on grade at 1/4" per foot slope with drainage fittings.
Also : Pretty sure you can't do that with your shower tailpiece, but i'll let someone from your area chime in on that. Ours have to be vertical only.
Journeyman Plumber
Old 01-04-2013, 08:33 AM   #4
Rewards Points: 214
Still in planning stage. No rush. How about this? Fittings 3 and 7 are rolled a little bit off the horizomtal.
Old 01-04-2013, 08:57 AM   #5
Roofmaster
Rewards Points: 2,210
Is this what is called a Flugglehorn? Always wanted to play a Flugglehorn.
Old 01-04-2013, 09:20 AM   #6
Doing it myself
Alan's Avatar
By my code, those vents should be coming off the top of the drain pipe, meaning 45* angle or greater. This means you have to hit the wall first with the drain, vent up, then travel to your trap & or trap arm.
If I were trying to get this plumbing done, i'd have asked for the concrete to be opened up on the other side of the wall as well so my tie ins could be over there, vent up in the wall, and then be more of a straight shot to where my drains are located.
Journeyman Plumber
Old 01-04-2013, 12:04 PM   #7
Rewards Points: 214
Yeah I was afraid of that. Guess I will have to demo more of the concrete in the laundry area (which I wanted to not do) and move the double-wye (fitting #1) back.
Thaks for the constructive advice and not just making fun of my work of art
Old 01-04-2013, 12:19 PM   #8
Plumber
Rewards Points: 672
why is the trap reduced to 1.5"? Showers require a 2"
Old 01-04-2013, 12:22 PM   #9
Rewards Points: 214
That can be kept at 2"
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
3" ABS toilet flange 3 1/2" too high in basement floor fusion2k Plumbing 3 08-26-2012 12:41 PM
Toilet and Shower Rough In Dimensions VikingDinKC Plumbing 16 05-13-2012 01:50 PM
Basement Toilet Gurgling zoner2009 Plumbing 4 01-30-2010 11:12 AM
Basement Toilet Rough In - Help atm Plumbing 3 06-06-2009 11:04 AM
