Old 05-28-2009, 12:55 PM   #1
Default Basement toilet rough in stub - new flooring coming
We have a toilet rough-in in our basement that we are finishing. I have flooring (laminate wood) being installed next Tuesday and I am wondering if I need to do anything to the rough-in stub proir to the flooring crew coming in.
ThunderCAT is offline   Reply With Quote
Old 05-28-2009, 06:31 PM   #2
you can get larger/thicker/taller beeswax seals or if you are raising the floor a whole lot, they make a flange extender.
bloom42 is offline   Reply With Quote
Old 05-28-2009, 06:56 PM   #3
Right now I have a 4" PVC pipe coming out of the concrete floor about 8" then capped (fully concreted in). From what I have been reading, I could get a flange that will sit (and be glued) inside this. Should I do this first, securing it to the concrete floor with TAPCONS, or do I leave it as is, lay the floor around it, then cut the 4" PVC flush to the floors finish grade, then seat the flange in it. If I do the second option, do I need to fasten the flange with TAPCONS (through the laminate) for stability?
Old 05-28-2009, 07:36 PM   #4
JDC
Plumbing Contractor
JDC's Avatar
I'd wait until the floor was in. Get a 4X3 flush flange to glue into the 4" PVC. The flush flange doesnt have a lip on it that would prevent it from sitting flush on the floor. Use the tapcons to secure the flange after its glued in.
JDC is offline   Reply With Quote
Old 05-28-2009, 08:01 PM   #5
Excellent, this is what I was planning on doing exactly.
Old 05-29-2009, 12:51 PM   #6
Your all set Thundercat. As JDC said, add the flange after the flooring is in. I suppose it's too late to talk you out of wood laminate flooring in your bathroom in favor of a nice tile floor.
Old 05-29-2009, 01:55 PM   #7
I went back and forth on if I should use laminate. I read a lot of comments supporting both sides (not to use it and that it's okay to use it as long as it's cared for). We finally decided to go with it because it's not a bathroom that will get heavily used, so wetness shouldn't be an issue. Also, with the cold MN winters and the concrete in the basement, I thought tile would be too cold, and we didn't want to invest in a heating system for the little this bathroom would be used.
More On This Topic
Applying the first of two PVC plastic bags for the lamination process. Learn how to make a prosthetic leg with these video instructions. Read More »
Hi, this is Jon, and in this video clip I'll be talking about fastener organization and storage. Now typically when you're building some type of a project and you go to your home center and buy some fasteners, you're going to have a few left over at the... Read More »
We are going to talk a little bit about the demolition that we had to do to get started with this project. As you can see this wall along here has been exposed. You can see the 2x6 construction. We came in and decided where the new door should be into... Read More »
Now we're ready to talk about actually glazing over your picture. There are lots of different glazing. There is laminate, glass, plexi, liquid laminate. They all do there own things about the pictures. Clear glass has no protection other than it reflects... Read More »
Concrete floors are long lasting, well supported and fairly simple to maintain. With stamps, patterns, stains and polishes, they are popping up in places beyond the garage and basement. Cleaning your concrete floors should be part of a regular home... Read More »
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 4 01-11-2009 01:06 PM
Toilet jpark Plumbing 18 01-05-2009 09:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 09:55 AM
Basement flooring choices Brik Building & Construction 23 01-27-2007 04:38 PM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 11:08 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
