Basement Toilet Backing Up Onto Basement Floor - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-06-2010, 12:27 AM   #1
Unhappy
Basement Toilet backing up onto basement floor
Hi,
Looking for some help with what is going on in my "new house". I bought a ~50 year old house from a flipper. The basement toilet & shower aren't used much and are now clogged. At the same time I'm getting sewer smelling water that is seeping into my basement when I plunge in the room against the outside wall. This is the side of the house where I'm sure all the utilities are buried. The water appears on the floor, at the outside wall.
Is the plumbing damaged, and backing up into my basement? Will I have to dig this all out?
Thanks in advance for your time!
Troubled is offline   Reply With Quote
Old 02-06-2010, 12:38 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Do you have a sewer pump for the basement bathroom?
Journeyman Plumber
Old 02-06-2010, 12:43 AM   #3
No Sewer Pump
Hi,
I don't believe so. I do know there were no building permits pulled. Thanks to my lawyer that did nothing when I asked him about any protection I might have against that. Not sure if it was required.
Thanks.
Old 02-06-2010, 12:47 AM   #4
Doing it myself
Alan's Avatar
Does the rest of the house drain well, or is that whats backing up into your basement?
Journeyman Plumber
Old 02-06-2010, 12:53 AM   #5
House Drainage
Hi,
It appears that the rest of the house is draining well. It is just the basement bathroom that seems to be backing up onto the floor of the adjacent room, along the outside wall, in the direction of where the water and sewage lines would be.
I'll run a few things to see if I see water pooling... but I don't believe it will be so.
Thanks again.
Old 02-06-2010, 01:03 AM   #6
House Drainage Part 2
It seems that the upstairs bathroom is not causing my basement to flood. I am hesitant to try anything downstairs until tomorrow, just to be sure.
Thanks again.
Old 02-06-2010, 07:23 AM   #7
New Information
Okay... 3 things in the basement. Clothes Washer, bathtub and toilet. If I turn on the clothes washer and run the bathtub, I get large air bubbles up from the toilet. Any thoughts / help?
Old 02-06-2010, 09:26 AM   #8
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 822
Sounds like either a vent issue or blocking issue, or both. My money is on both issues.
Aggie67 is offline   Reply With Quote
Old 02-06-2010, 11:32 AM   #9
Doing it myself
Alan's Avatar
Best shot is to call a drain cleaning company, and have them camera it. If you're using the plunger and water is coming in from outside, it is likely that something came apart, or is broken. I'd also be concerned about the water coming through the wall.... that is no good.
Journeyman Plumber
Tags
basement , plumbing , seeping , sewage , toilet
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 07:54 AM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 12:23 PM
Basement Floor Drain & Sewer Gas 1914 Home Plumbing 4 09-26-2009 03:46 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
