Basement Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2008, 01:26 PM   #1
basement toilet
I am going to refinish my basement and I am planning on putting a bathroom in. I want to put a toliet in about two feet away from where a pvc soil stack goes into the floor of the basement. I am wondering what options I have here. Can I bust some of the floor out and tee into the pipe there for the toliet? My other idea was to raise the floor up a bit and tee into the pipe above the floor. Is venting going to be an issue here also? I really want to avoid an upflush toliet or anything like that. Thanks for your help.
bjkPoker is offline   Reply With Quote
Old 02-19-2008, 04:08 PM   #2
Send a message via AIM to Marlin
If the soil stack runs into the floor chances are you can tie into it below the slab. Yes, you will need to vent the toilet, sink, and shower.
Marlin is offline   Reply With Quote
Old 02-20-2008, 10:56 AM   #3
Is there a standard way to vent basement fixtures? I know the soil stack vents to the roof. Do basement fixtures just have a vent sticking out the side of the house?
Old 02-20-2008, 04:01 PM   #4
You can not vent out the side of a house. You may be allowed to use AAVs depending on your local codes. They will have to have access panels though. Your other option is to run another line up and tie into an existing stack for your vent.
Old 02-21-2008, 07:30 AM   #5
Thanks for your help. I've heard of AAV's before but I forgot about them until you mentioned them. That should do it as long as my local codes allow it.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 01:22 PM
Basement Toilet Floods Every Time It Rain Tmb9862 Plumbing 12 10-29-2006 10:16 AM
Adding toilet in basement with tile on the floor Kyle Plumbing 6 09-13-2006 08:59 PM
