Basement Smells Horrible!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2011, 12:13 AM   #1
Help please! Recently bought a 90 y/o home. Every once in a while the basement smells like sewage. It is a finished basement, some mold on walls noted here and there. Nothing substantial. The smell gets worse the more laundry we do. We have two drains in the one end not finished, and I have poured multiple gallons of water/cleaner down them in order to make sure they are not dry. I have attempted to locate every vent down there and cap (if it does not make it all the way up). Have had a ton of rain here in western Pa this month and the place is dry as a bone. One day, no smell. The next, horrible. We have an interior french drain that appears to be fine, actually, no smell at all from there. What can we do??? It's driving me, and the wife, nuts. Thanks
llmauro77 is offline   Reply With Quote
Old 05-22-2011, 07:12 AM   #2
DIY staff
Rewards Points: 7,174
You are on the right track,looking for improper vents---The most common culprit is the vent for the ejector pit----when the furnace kicks on,negative pressure is created---thus sucking sewer gas out of the vent.
In an antique house--also check for a cracked iron drain pipe or a bad lead joint.---Mike---
Old 05-22-2011, 09:00 AM   #3
Thanks mike. Where would the vent for the ejector pump be? Thanks
LLMAURO is offline   Reply With Quote
Old 05-22-2011, 09:17 AM   #4
DIY staff
If you have an ejector pit there will be two pipes entering the lid of the pit---one carries away the water (it will have a back flow valve) the other is a vent pipe.---If the lid and pipes are not sealed properly sewer gas can be sucked into the room when there is negative pressure--
Or if the weather outside forces air down the roof vent.--
Do check for flaws in the old cast iron drains ----if they are as old as I think there may be cracks or open lead joints.--Mike--
Old 05-22-2011, 10:08 AM   #5
Thanks for your help mike. I'll check those out.
The Following User Says Thank You to LLMAURO For This Useful Post:
oh'mike (05-22-2011)
Old 05-22-2011, 04:29 PM   #6
Ok. So one day later, I capped off an inch and a half vent near the washer, and my wife did no laundry today. No sewer smell what-so-ever. So, could that horrible smell
Have come from that simple vent, or is it something more involved associated with the washer drainage? Thanks for your help in this frustrating matter!
Old 05-22-2011, 05:38 PM   #7
DIY staff
A big fart can from a small hole.
Old 05-22-2011, 05:48 PM   #8
Gosh I hope that's what it is!!! We will see. On now to figuring out the leaking bathroom that is destroying my porch ceiling. Ahhhhhh, the luxuries of home ownership....
Old 05-22-2011, 06:06 PM   #9
DIY staff
Enjoy your home----Mike----
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 03:26 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 07:50 PM
Do I need to waterproof my basement if I already have a french drain? buratti Building & Construction 4 03-20-2010 04:32 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 12:07 PM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 10:09 AM
