Basement Sink Rough-in Drain Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2013, 10:20 PM   #1
Rewards Points: 236
Question
I am fixing to frame the area of my basement where a full bathroom will be.
There are 3 pipes, the sink drain pipe, toilet drain pipe, and shower drain pipe. I am pretty sure which one is which at this time (see the pictures).
Basement Sink Rough-in Drain Pipe-plumbing1a.jpgBasement Sink Rough-in Drain Pipe-plumbing2a.jpg
I will be installing 2" XPS insulation panel on the wall, the uses 2x4 lumber to frame.
What I am puzzled is the distance of the sink drain pipe. It is 6.5" from the concrete wall and it extends from the floor to the ceiling. If I subtract 5.5" (2" XPS + 3.5" lumber), the pipe is 1" outside the wall.
Should this pipe sits behind the frame wall?
If I put the frame in front of the pipe, part of the bathroom wall (i.e. where the sink will be) is bumping out about 11.5" from the rest of the wall. Is that not odd?? Did I miss something?
Any input is appreciated.
325_man is offline   Reply With Quote
Old 04-30-2013, 08:37 PM   #2
Rewards Points: 236
Anyone?
Old 04-30-2013, 09:03 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 356
The pipe should be in the wall. Put the room side of the wall flush with the room side edge of the pipe.
Also check that you have 12.5" from the face of the wall to the center of the 3" toilet pipe- this is really the critical measurement
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (04-30-2013), Javiles (05-02-2013)
Old 05-01-2013, 06:53 PM   #4
Rewards Points: 1,706
Your plumber was a lazy and cheap one and did not want to roll the drain up above your footer. That would have added a few more fittings..... Just saying!!!
Old 05-02-2013, 08:32 AM   #5
Rewards Points: 236
Thank you!
I guess I need to use 2x6 lumbers for this part of the wall as the drain pipe is about 2.5", or do you think 2x4 lumber can handle this?
Note: it is not a load bearing wall, and I will be putting a metal strip on the bottom and top plates preventing any nail punctures.
Old 05-02-2013, 08:39 AM   #6
Rewards Points: 236
Well, what commercial builders build a house with high quality? All they care is maximizing the profit and minimizing the spending/cost. If it means get the laziest and the cheapest plumber as long as the work meet the code, so be it.
This is not the only thing that I have been dealing with in the last few months fixing my basement.
The consumers like me are the victims. Good thing that I didn't pay them to finish the basement because all these stuff would have been hidden and I have to pay a lot to fix them later.
Deep Pipe Clog - Epic Battle Digi Plumbing 37 02-02-2013 12:48 PM
drain pipe for kitchen sink ron097 Plumbing 1 09-28-2011 12:02 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 10:41 AM
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 12:11 PM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 09:36 PM
