-   -   Basement Sink Rough-in Drain Pipe (http://www.diychatroom.com/f7/basement-sink-rough-drain-pipe-178323/)
325_man 04-28-2013 10:20 PM
3 Attachment(s)
I am fixing to frame the area of my basement where a full bathroom will be.
There are 3 pipes, the sink drain pipe, toilet drain pipe, and shower drain pipe. I am pretty sure which one is which at this time (see the pictures).
Attachment 70023Attachment 70024
I will be installing 2" XPS insulation panel on the wall, the uses 2x4 lumber to frame.
What I am puzzled is the distance of the sink drain pipe. It is 6.5" from the concrete wall and it extends from the floor to the ceiling. If I subtract 5.5" (2" XPS + 3.5" lumber), the pipe is 1" outside the wall.
Attachment 70025
Should this pipe sits behind the frame wall?
If I put the frame in front of the pipe, part of the bathroom wall (i.e. where the sink will be) is bumping out about 11.5" from the rest of the wall. :eek: Is that not odd?? Did I miss something?:confused1:
Any input is appreciated.
325_man 04-30-2013 08:37 PM
Anyone?
TheEplumber 04-30-2013 09:03 PM
199 Attachment(s)
The pipe should be in the wall. Put the room side of the wall flush with the room side edge of the pipe.
Also check that you have 12.5" from the face of the wall to the center of the 3" toilet pipe- this is really the critical measurement
Ghostmaker 05-01-2013 06:53 PM
Your plumber was a lazy and cheap one and did not want to roll the drain up above your footer. That would have added a few more fittings..... Just saying!!!
325_man 05-02-2013 08:32 AM
Thank you!
I guess I need to use 2x6 lumbers for this part of the wall as the drain pipe is about 2.5", or do you think 2x4 lumber can handle this?
Note: it is not a load bearing wall, and I will be putting a metal strip on the bottom and top plates preventing any nail punctures.
325_man 05-02-2013 08:39 AM
Well, what commercial builders build a house with high quality? All they care is maximizing the profit and minimizing the spending/cost. If it means get the laziest and the cheapest plumber as long as the work meet the code, so be it.
This is not the only thing that I have been dealing with in the last few months fixing my basement.
The consumers like me are the victims. Good thing that I didn't pay them to finish the basement because all these stuff would have been hidden and I have to pay a lot to fix them later.:furious:
