Basement Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2009, 12:51 PM   #1
basement sink drain
I want to install a bar sink in my basement. Is there anyway to run the drain other than cutting the floor and installing a line to the riser?
rfrench1 is offline   Reply With Quote
Old 01-23-2009, 05:49 PM   #2
wheres the riser in comparason to the bar sink?
zosoplumber is offline   Reply With Quote
Old 01-23-2009, 07:17 PM   #3
basement sink drain
The riser is approx. 25ft from the sink. The bar has not been installed and everything is in the design stage at this time.
Old 01-24-2009, 06:51 AM   #4
they make sump pumps that fit under the sink. You could hook that up and run the 3/4" line to the drain and drill in a saddle or cut in a wye.
google it, you'll find them. way easier than cutting the floor.
II Weeks is offline   Reply With Quote
Old 01-24-2009, 07:17 AM   #5
or, if it is an option, move the bar in the are of the stack, so you coud just cut a tee in the stack and run the line under the bar, as for water lines not sure if you have any exposed in the floor joist above your head.
Old 01-24-2009, 08:24 AM   #6
Thanks to you both. I have seen the sump pumps for under the sink and will most likely use that. Home Depot has them on thier sight. I'll just need to take a actual look at them in thier store if they have them. As for the water lines I have a cold line directly above and will need to tap into the hot and run a line to the sink.
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
sewer backup and stench jayhill Plumbing 12 08-13-2008 11:06 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 02:30 PM
