Old 01-04-2008, 08:57 PM   #1
basement sink
had to put in a new basement sink, the other one had a crack in it. it had all the old metal piping for the drains. i changed everything over to pvc except the cast iron piece in the floor. the piece in the floor is about 5 1/4in in diameter from outside to outside. the 4 in rubber sleeve is to small and the 6 in rubber sleeve is to big. what can i use to run the 1 1/2 pvc into the 5 1/4 in cast iron.
bobcatnj is offline   Reply With Quote
Old 01-04-2008, 10:45 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
basement sink
You just need to go to a plumbing supply house where they know what you need, which will involve a no-hub coupling made for cast iron-to-PVC. It sounds like you're trying to use a standard Fernco coupling.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Sink Depth dilemna Yippee Plumbing 9 01-01-2008 01:25 PM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 10:55 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
