Old 05-22-2011, 10:42 AM   #1
twags
Basement shower filling with water from upstairs sink.
Hello all,
I am having an issue with the my basement shower (small - approximate 2.5' X 2.5' shower - lowest drain in the house) filling with water from my upstairs sink. The plumbing from my sink / dishwater goes down through the drain in the basement shower. My bathrooms' plumbing upstairs take a different path so there is no sewage going through this drain.
I have tried liquid plumber a couple times without success. I have also tried a hand snake and plunger. I have been using my shop vac. to suck the water out. I will plunger, then put the hose of the shop vac. down the drain for a while attempting to suck anything out that may be stuck. The drain will "work" (the shower basin will fill up then drain slowly - can't use too much water or it will overflow) for about a 1 - 2 weeks before I have to use the plunger / shop vac. again.
Does anyone have any advise on how to fix this problem? I am hoping it's not a serious issue where I need to have my front yard dug up and have the pipes replaced (major obstruction / roots growing through the pipes)! Maybe an "power snake" will do the job? Any advise would be appreciated...thanks!!
Tim.
twags is offline   Reply With Quote
Old 05-22-2011, 06:02 PM   #2
A do it yourself power snake will probably not cut a large enough hole through roots in the pipe evn thought it goes all the way through.
I wouls suggest having a professional come in to clear out the main drain line.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
twags (05-23-2011)
Old 05-23-2011, 09:40 AM   #3
twags
OK, will do...thanks Allen!
Old 05-23-2011, 10:50 AM   #4
be cautious of the big franchise operations Their techs. work on commission and will try to upsale whether you need it or not. Just my opinion. If in doubt, get a second opinion from a service plumber who can run a sewer-cam in the pipe!
plumberinlaw is offline   Reply With Quote
Old 05-23-2011, 04:02 PM   #5
twags
Great advice about the franchise operations and I haven't heard of a sewer cam.
I am very cautious when I get anything repaired. Just like some mechanics when you go get your car fixed - upsale!! So I TRY to learn as much as possible and do the work myself. Some things (like in this case) I really need a professional. I think I know someone that will come out and give me a fair assessment.
Thanks again!!
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
No water upstairs sink only? she211 Plumbing 15 01-17-2009 02:26 PM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 11:42 AM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
