-   -   Basement shower filling with water from upstairs sink. (http://www.diychatroom.com/f7/basement-shower-filling-water-upstairs-sink-105183/)
twags 05-22-2011 09:42 AM
Hello all,
I am having an issue with the my basement shower (small - approximate 2.5' X 2.5' shower - lowest drain in the house) filling with water from my upstairs sink. The plumbing from my sink / dishwater goes down through the drain in the basement shower. My bathrooms' plumbing upstairs take a different path so there is no sewage going through this drain.
I have tried liquid plumber a couple times without success. I have also tried a hand snake and plunger. I have been using my shop vac. to suck the water out. I will plunger, then put the hose of the shop vac. down the drain for a while attempting to suck anything out that may be stuck. The drain will "work" (the shower basin will fill up then drain slowly - can't use too much water or it will overflow) for about a 1 - 2 weeks before I have to use the plunger / shop vac. again.
Does anyone have any advise on how to fix this problem? I am hoping it's not a serious issue where I need to have my front yard dug up and have the pipes replaced (major obstruction / roots growing through the pipes)! Maybe an "power snake" will do the job? Any advise would be appreciated...thanks!!
Tim.
AllanJ 05-22-2011 05:02 PM
A do it yourself power snake will probably not cut a large enough hole through roots in the pipe evn thought it goes all the way through.
I wouls suggest having a professional come in to clear out the main drain line.
twags 05-23-2011 08:40 AM
OK, will do...thanks Allen!
plumberinlaw 05-23-2011 09:50 AM
be cautious of the big franchise operations Their techs. work on commission and will try to upsale whether you need it or not. Just my opinion.:yes: If in doubt, get a second opinion from a service plumber who can run a sewer-cam in the pipe!
twags 05-23-2011 03:02 PM
Great advice about the franchise operations and I haven't heard of a sewer cam.
I am very cautious when I get anything repaired. Just like some mechanics when you go get your car fixed - upsale!! So I TRY to learn as much as possible and do the work myself. Some things (like in this case) I really need a professional. I think I know someone that will come out and give me a fair assessment.
Thanks again!! :thumbsup:
