Basement Shower Drain Relocation - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2008, 09:25 PM   #1
First time poster....
I took a jackhammer to the basement to relocate the shower drain for 48" shower base; see before and after pics. Looking for opinions before I glue together. I used 2" pipe, slope is over 1" from trap to long raduis 90 degree elbow, which is approx 3'. Pipe lines up well, drain screws right into the base. Thanks in advance for those that reply.
Basement Shower Drain Relocation-davis-2008_basement-009.jpg   Basement Shower Drain Relocation-davis-2008_basement-011.jpg   Basement Shower Drain Relocation-davis-2008_basement-013.jpg
rmdhokie is offline   Reply With Quote
Old 07-01-2008, 10:17 PM   #2
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Great looking job, you're hired! Just make sure you pack dirt in really good under the pipe so when you install the shower base it doesn't push the pipe down.
I have also started using silicone instead of putty to seal around the drain when it is installed in the base. It makes it a pain in the neck if you ever need to replace it but it really reduces leaks down the road.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
Basement shower drain help.. helpless handyman Plumbing 79 02-26-2008 09:39 PM
Basement shower drain new diy'er Plumbing 3 01-17-2008 01:12 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
