Old 02-26-2008, 10:16 PM   #76
Basement shower drain help..
Here you Ron, it's a Mustee Fiberglass Shower Floor 3636M:
[img=http://img207.imageshack.us/img207/1627/showerbase2di0.th.jpg]
[img=http://img84.imageshack.us/img84/3205/showerbase3fd1.th.jpg]
[img=http://img337.imageshack.us/img337/4599/showerbaserp3.th.jpg]
It's the one that you slip over the 2 inc pvc, then you have to hammer the rubber around the pvc to make seal. My question is can I use this? My pvc pipe will then have to be cement to the ground so it won't move. Let me know what you think, or should I look for another one? Also it doesn't have predrilled holes, so I would have to predrill and screw to the rough framing. All your ideas are welcomed. Also can cement boards be placed over the lip as well?Thanks
Here a link:
http://doitbest.com/Shower+stalls-Mu...sku-438725.dib
helpless handyman is offline   Reply With Quote
Old 02-26-2008, 10:22 PM   #77
Journeyman Plumber
Ron The Plumber's Avatar
Looks good, yes predrill the holes and put mortar under the base, you can use cement boards if you wish.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 02-26-2008, 10:30 PM   #78
Ron, so I will have to cement the floor where the p trap will be, and just leave the 2 inc pipe sticking out? This way the pipe won't move when I am pounding that rubber in around the pvc. Will the concrete harm the pvc? I didn't want to cement the pvc trap, but I guess I don't have any choice now, or I should say there is no other way?
Old 02-26-2008, 10:32 PM   #79
Journeyman Plumber
No you don't want to cement the pipe in place, just make sure the trap is sitting on firm ground, and the pipe in vertical and on center, should work just fine.
Old 02-26-2008, 10:39 PM   #80
Sounds better, I didn't want to cement the pipe!
Thanks Ron
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Basement shower drain new diy'er Plumbing 3 01-17-2008 02:12 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
