Basement Shower Drain Help.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2008, 08:46 PM   #61
Journeyman Plumber
Ron The Plumber's Avatar
Sure can
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-19-2008, 08:57 PM   #62
Thanks, I want to add a cleanout near the end where is starts to meet the outside piping. Does it make sense to put it there? Also should I do the clean out 2" or 3" ?
helpless handyman is offline   Reply With Quote
Old 02-19-2008, 09:07 PM   #63
Journeyman Plumber
3" cleanout right where you said.
Old 02-20-2008, 08:36 PM   #64
On the cleanout, using the wye do I pipe straight up and then add one of those plugs, or does it have to go on an angle? Thanks
Old 02-20-2008, 08:39 PM   #65
Journeyman Plumber
Straight up is fine.
Old 02-20-2008, 08:46 PM   #66
Old 02-20-2008, 09:35 PM   #67
Journeyman Plumber
Here is another way to plumb toilet in if depth is an issue.
Old 02-21-2008, 03:18 PM   #68
I like this, but will need further details when you have a chance. Thanks
Old 02-21-2008, 06:10 PM   #69
Journeyman Plumber
Come off the mainline using a wye 4 x 3 then hit a 45 el towards the center of toilet flange, before the 90 turn up towards the flange use a 3 x 3 wye with a 45 elbow, invert this on a 45 slope, then use a 45 el to head towards the wall, and then LT 90 up into the wall, you have have a legal vent and drain for the toilet.
Old 02-21-2008, 06:25 PM   #70
How far apart should I start that 4x3 wye from the closet flange?
Old 02-21-2008, 07:25 PM   #71
Journeyman Plumber
Put it far enough away so you won't have a problem getting the fittings in. 6' to 7' away, need the space to get the vent happening.
Old 02-22-2008, 03:24 PM   #72
Okay Ron, got everything ready for tomorrow morning, last but not least. How far should that 3x2 wye be from the toilet flange? Does it matter?
Old 02-22-2008, 07:12 PM   #73
Journeyman Plumber
Don't matter how far, as long is it is with in 6' that 6' includes the toilet stub up, so if you have 1' on the drop to the 90 then you can go up to 5' before you tie the 3 x 2 wye in there.
Old 02-25-2008, 08:56 PM   #74
Ron, everything went well. I bought a shower pan, and it one of those that you can buy the additional panels for. I want to use just the shower base only, and frame around it and add tile later on. My question, this pan comes with a small plastic neck under it, like a piece of pipe all in one piece attached to the pan. Can I use this pan for what I intend to do, or do they sell special pans for this. Want to stay away from mud pan. Thanks
Old 02-26-2008, 12:26 AM   #75
Journeyman Plumber
Picture of the pan or a link showing this pan would be nice.
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 11:54 AM
Basement shower drain new diy'er Plumbing 3 01-17-2008 01:12 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 05:44 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 08:59 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
