02-18-2008, 08:51 PM
#46
Journeyman Plumber
Basement shower drain help..
Had to work you know, this is not a job on this forum it's all volunteer
Fix it right the first time, so you won't have to fix it a 2nd time.
02-18-2008, 08:54 PM
#47
I understand Ron, I was off today and I assumed you were off too. This is wow! I picked up all the wyes you told me, but couldn't find a 3 inc heal, and don't know what it looks like.
[img=http://img216.imageshack.us/img216/3555/dscf0066rt3.th.jpg]
02-18-2008, 08:58 PM
#48
Journeyman Plumber
I'm looking for a picture now
02-18-2008, 09:15 PM
#49
Journeyman Plumber
This is not a good picture of a low heal, here is what it will look like
And the tee 2 x 1-1/2 x 2 SanTee they make.
02-18-2008, 09:29 PM
#50
okay Ron, so on that low heal tee, will I have to reduce the top to 2inc for the venting? Also on the san tee 2x11/2x2,(shower drain) wouldn't the 1 1/2 be in the middle, I thought the drain would be 2 inc?
02-18-2008, 09:34 PM
#51
Journeyman Plumber
1-1/2 is on top of the 2 x 1-1/2 x 2 santee, the side inlet is always last in the name of the fitting. Name goes, Bottom, Top, Side
They make low heals that are already at 2", but you can reduce the tee if you like, set the combo straight up, set tee of lowheal pointed towards the closet flange and the get the vent into the wall.
02-18-2008, 09:49 PM
#53
Journeyman Plumber
Yes right on the top of the combo turned towards the flange, then vent off the top of the 2" into the wall.
02-18-2008, 09:52 PM
#54
Journeyman Plumber
Originally Posted by helpless handyman
Sweet, I'll send you the bill
02-18-2008, 09:57 PM
#55
Ron, I give you all the credit on that one Last but not least, I am basically putting all 3 wye combo facing up? What had me puzzled was the wye combo. I knew what a wye was, but didn't know what a wye combo look like until I google it. I was wondering how the heck was a wye going to work there...Thanks man, your the BEST! I will be able to sleep tonight and get my parts hopefullt tomorrow.
02-18-2008, 09:59 PM
#56
Journeyman Plumber
Sure you can, should make it easy to get the vents and drain for lav in the wall that away.
02-18-2008, 10:05 PM
#57
Before I go to sleep, on the toilet drain, do I use an elbow when I'm turning up?
02-18-2008, 10:07 PM
#58
Journeyman Plumber
Use a short turn 90 on the turn to the closet flange. Set Flange 13" off the rough back wall, min of 15-1/2" from the side wall.
02-18-2008, 10:10 PM
#59
Got it Thanks!
02-19-2008, 09:21 PM
#60
I couldn't find a wye combo, can a wye with a 1/8 street elbow do?
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
