Basement Shower Drain Help.. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2008, 09:55 PM   #16
Journeyman Plumber
Ron The Plumber's Avatar
Like this and where is that sewer line at inside the room?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-17-2008, 10:08 PM   #17
Thanks for the drawing, the sewer line is running I would say around 17 inches behind the toilet, (it is not in the room, but 17 inches back). Also, there is a 2 inc vent stack about 3 feet from the toilet, so I can tie into that for venting, it goes all the way up and ties to the main stack above all bathroom fixtures upstairs bath.
helpless handyman is offline   Reply With Quote
Old 02-17-2008, 10:19 PM   #18
Journeyman Plumber
How about this.
Old 02-17-2008, 10:23 PM   #19
So everything has to be vented before it hits the stack? Also the drain line goes from left to the right towards the main sewer discharge. Am I using wyes on everything?
Old 02-17-2008, 10:43 PM   #20
Journeyman Plumber
Yes wye for all the branch lines, stack? what stack?, are you not working ground level?
Old 02-17-2008, 10:47 PM   #21
Sorry about that, I meant ground level sewer line. Also the wye do I put them side way, or a little higher up? Also everything vented before it hits main sewer line??? On the toilet I don't have enough room to install another wye or tee for venting., what can be done??? Can I vent from the pipe thats going up to the flange, since its about 3 feet deep?
Old 02-17-2008, 10:49 PM   #22
Journeyman Plumber
Sideway is fine just keep the 1/4" per ft' grade.
Old 02-17-2008, 10:56 PM   #23
How about the toilet venting???
Old 02-17-2008, 10:58 PM   #24
Journeyman Plumber
Use a wye combo on it's back vent into the back wall if you can.
Old 02-17-2008, 11:05 PM   #25
Your talking plumbing language. Do you mean to use two wyes? One for the drain and one for the venting? If thats the case, I don't have room for it.
Old 02-17-2008, 11:08 PM   #26
Journeyman Plumber
Can you use a tee for the vent, How deep is the line from you finish grade?
Old 02-17-2008, 11:14 PM   #27
Its about 2 1/2 feet deep, where would the tee be placed?
Old 02-17-2008, 11:17 PM   #28
Journeyman Plumber
OK use a low heal 90 at the wall just behind the toilet then a long turn 90 below the low heal, then tie into the wye combo off of mainline connection.
Low heal 90 will give you your vent vertical in the wall.
Old 02-17-2008, 11:27 PM   #29
Ron, I'm lost. I am not a plumber...
Old 02-17-2008, 11:28 PM   #30
Journeyman Plumber
Here how about this?
Installing basement shower drain atilla137 Plumbing 5 09-03-2009 12:54 PM
Basement shower drain new diy'er Plumbing 3 01-17-2008 02:12 PM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
Food backing into shower drain Manuel6 Plumbing 5 11-23-2006 09:59 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
